(Topic ID: 50762)
Metallica owner's thread
By swampfire
7 years ago
  • 18,076 posts
  • 1,013 Pinsiders participating
  • Latest reply 2 hours ago by Juicerc51
  • Topic is favorited by 374 Pinsiders
There have been 3,138 images uploaded to this topic. (View topic image gallery).
5 key posts have been marked in this topic (Show topic index)
There are 18076 posts in this topic. You are on page 346 of 362.
#17251 11 months ago
Howdy crew,
Would someone do me a favor and check one of the settings in the menu to see if, it reacts the same as mine, and tell me what the purpose is perhaps...
In the diagnostics menu under game specific options there is the option to change the intensity of the RGB for the playfield arrows. I can change the brightness for all three channels and accept them, but when I back out of the menu, it changes the setting back to 100%.
#17252 11 months ago
I can check when I get home tonight. do you happen to know the setting no for this?
#17253 11 months ago
Quoted from pinhi:
Got mine from HankScorpio (pinmods) a couple years ago. He may still make them?
Are these suitable for a MOPLE?
On another note has anyone powdercoated their MOPLE in any color other than the stock silver? I’d love to see pics
#17254 11 months ago
Quoted from BillySastard:
Check the Cliffy protector that is on the left. It almost looks like it's sitting over the shooter lane so that the ball doesn't sit properly in the shooter lane.
Sorry, I didn't see that anyone had replied to me. Can you please be a little more specific? I didn't install the Cliffy, and new to all this, so I'm not really sure what could be creating the ball to not sit properly.
#17255 11 months ago
Quoted from embryon:
If it's the shaker pcb, I replaced the transistor twice and it blew both times. Only once I swapped it for a new pcb the problem has gone. So maybe contact stern
After reading this, I took your advice. Marco had a new board in stock, so i ordered it. I also repaired the current board. I guess now i have a back up....
#17256 11 months ago
Just wanted to throw a shout out to Sparky for a killer product with his Micro Display. Superb as always. Really ties the room together.
+1 for ease and awesomeness.
#17257 11 months ago
Quoted from allsportdvd:
Sorry, I don’t know.
#17258 11 months ago
Quoted from chaz009:
The Cliffy protector is the thin piece of metal that sits on the right side of the shooter lane, where the ball ejects out of the trough. Check to make sure that it's not sitting over the shooter lane. It needs to sit flush with the flat part of the wood, but not past that and over the grooves. If it's too far to the right it will impede the ball from shooting straight. Hope that explanation helps.
#17259 11 months ago
Anyone have an EOS Left flipper issue on this game, and how did they go about fixing it short of a flipper rebuild kit?
#17260 11 months ago
Quoted from Mikedenton49:
+1 for ease and awesomeness.[quoted image][quoted image]
Can you give more info on this one looks cool
#17261 11 months ago
Quoted from zpinman370:
I posted about these on the previous page toward the top. You can find them in my Pinside Shop or on Mezelmods.
#17262 11 months ago
Quoted from Ripshill:
What kind of issue?
Rob
#17263 11 months ago
Quoted from Rob_G:
What kind of issue?
Rob
Hi Rob,
It appears as if the left flipper is a touch slow as a result of it. Honestly, I was just going to wait till the rebuild kit arrived to fix the issue, but was hoping for an interim solution.
#17264 11 months ago
Hi Rob,
I'm not sure the EOS is your problem by that description. If you want, I can stop by and take a look.
Rob
#17265 11 months ago
Quoted from Rob_G:
Rob
Hi Rob,
I actually did a full flipper rebuild this weekend. The error is now gone. I had no idea how long it would take for the kit to arrive and just wanted an interim solution. Thanks for the offer!
#17266 11 months ago
Sorry if this has been asked in the past, but two things have always bugged the hell out of me about this game. Has anyone done anything as far as updating or programming to make songs selectable between balls, or made it so that the songs don't play in a continuous loop before shooting the ball? I noticed that on newer music themed games like IMDN these two things aren't an issue.
#17267 11 months ago
I reflowed the power connector on the board underneath the machine to solve my disappearing GI light issue but it seems to have returned after about 3 weeks. has anyone experienced this and what was their fix?
#17268 11 months ago
Quoted from j_m_:
I replaced the power connector for this board on my game. Premium right?
Rob
#17269 11 months ago
I replaced the 2x white flashers bulbs with blue at the top of the grave yard and near the rising cross. Made it less blinding.
#17270 11 months ago
Quoted from Rob_G:
Rob
yep, it's a premium. did you replace the male post part soldered to the board or the wired end (re-terminating the wires)?
#17271 11 months ago
Quoted from sohchx:
Not as far as i know.
#17272 11 months ago
Any idea why the snake and electric chair lights would be out on every shot except the left loop? It is a Premium. All fuses look good and I did not have any loose connections on the boards. Here is a video:
#17273 11 months ago
Quoted from Rickwh:
You have the newer “metal back box” Met. Met came both with wooden backbox and metal. The metal ones are newer and they switched to that in 2014 or so. Metal back boxes don’t have t molding across the front. I think the two holes are supposed to have rubber stoppers cause that corresponds to where the head rests on the cab side rails.
So do we know where those rubber stoppers can be bought? I don't see anything on Marcos. And I too have empty holes and scraped paint in lieu of two little pieces of rubber.
#17274 11 months ago
Quoted from arcyallen:
Will any of these work? I have wooden backbox so nothing to compare to.
https://www.pinballlife.com/rubber-grommets.html
#17275 11 months ago
it might be these
https://www.marcospecialties.com/pinball-parts/38-6577
#17276 11 months ago
Any suggestions on the best mod to add on Met Pro? Have shaker, fangs, and color dmd. Thank you
#17277 11 months ago
Quoted from t2:
Sub
#17278 11 months ago
Quoted from t2:
External volume control, external sub. Then of course others follow
#17279 11 months ago
Dude ya beat me by a min! Lol
#17280 11 months ago
Quoted from t2:
Pinwoofer kit. It’s kind of expensive but definitely worth it.
#17281 11 months ago
Spinners, knocker, and lit drops for the pro are nice too
#17282 11 months ago
Subwoofer. This enhances game play. Visual mods are cool, when you are just looking at it.
#17283 11 months ago
Quoted from Spelunk71:
We've extended our 20% off sale through Sunday. Should you need it, technical support is included:
https://pinside.com/pinball/forum/topic/new-amplified-subwoofer-kits-by-pinwoofer/page/8#post-5459863
You'll never look back! Thanks
#17284 11 months ago
Quoted from onemoresean:
Spinners, knocker, and lit drops for the pro are nice too[quoted image][quoted image]
Looks good. Are those regular or transparent targets?
#17285 11 months ago
Quoted from LargemouthAss:
All of those inserts that are not working are controlled by the RGB LED driver board under the playfield. Failure of the power connector is a common problem.
https://pinside.com/pinball/forum/topic/metallica-lights-issue
Rob
#17286 11 months ago
PinWoofer Super Kit is a must for Metallica Pin, or any other music pin for that matter.The Clarity from the backbox speakers, along with that Kick ass Sub, brings it all together the way it should be heard ! Clear and Loud !!Much better to have the whole package enclosed inside the Pin, instead of a clunky Sub under the Cabinet, Dan will take care of you every step of the way, and follows up just to make sure all is well ! the product is Grade A along with the Customer Service Before, During, and After the sale !!
#17287 11 months ago
Quoted from MJW:
I used translucent drop targets.
http://pinball-mods.com/oscom/pinballcenter-m-2.html
I also added a translucent orange target
#17288 11 months ago
I also added a translucent orange target[quoted image]
Nice. Got a pic of the lit translucent? I issued eyeball target for piston target.
#17289 11 months ago
Quoted from MJW:
Nice. I also think Zitt sells white translucent targets. I used eyeball target for piston target.
#17290 11 months ago
I just joined the club with a MOPLE. Can anyone tell me where these go?
#17291 11 months ago
I just joined the club with a MOPLE. Can anyone tell me where these go?[quoted image]
I think those are for the speaker grilles.
#17292 11 months ago
I was gonna suggest anywhere but on the playfield!
#17293 11 months ago
Those came installed on the speaker grills as yzfguy mentioned. They also came installed on the Monster and Road Case Prem, even though the original flyer doesn't show them pictured on any of the games.
Curious why they were removed. Did the previous owner add a speaker light kit or other grill piece in their place?
Search the topic gallery of this thread, and you'll see several pics with these installed.
#17294 11 months ago
Quoted from Sparky:
My final run monsters prem didn't come with these
#17295 11 months ago
#17296 11 months ago
Pictures above are original wood speaker panels. Do these fit the new style speaker panel with round holes?
#17297 11 months ago
Quoted from Mr_Outlane:
Thank you
#17298 11 months ago
They should fit fine on the grills in the round speaker holes, but I'm not sure if they come on any of the round hole panels originally.
The trick on adding them to a new speaker grill would be deciding where to put the mounting holes in the grills. If you had someones originals it would be easy enough....just doing it yourself from scratch probably wouldn't be to bad either depending on how particular you were to having them placed and angled like the originals. I think the most important thing would be to make sure you have the same hole placement on each of the grills so they at least match each other.
#17299 11 months ago
All good, found the original grill with the correct holes for these. Now on to selling the acrylic ones and get some lights behind the speakers
#17300 11 months ago
All good, found the original grill with the correct holes for these. Now on to selling the acrylic ones and get some lights behind the speakers[quoted image]
Now those acrylic designs (you have pictured) WOULD NOT look right behind the round speaker holes. They were cut before they released MET with a round hole speaker panel. If you would mount them behind the round holes you would see the red frames poking out at the top, left and right sides of each round speaker hole. Just something to keep in mind if you are selling them.
Revised versions of all of the acrylic designs that I sell have been done when a "round holed" speaker version of the games were released (AC/DC, Iron Man, Metallica, Spider-Man)....with the only exception being my Black Spider-Man design as there was no good way to make a single design that looked correct in both the original square speaker hole and the vault round ones. As you can see on these revised designs...the frame is cut away on the inside edges so it is not seen around the round speaker holes when mounted. This change was done as soon as each games round speaker holed version was announced, so no one needs to specify or be concerned with anything when ordering.
Doug (SpeakerLightKits.com)
$ 29.99
Bent Mods
$ 50.00
$ 54.99
