Quoted from Wildbill327:Just wondering,does your back box rattle more when the shaker is activated after installing your lcd dmd?
I don't have the shaker in it yet.
I could see how it would rattle depending on the installation of the color DMD though. They listed the 2 washers on the posts as optional, but then the spacers (the stock ones that you reuse) would be loose because the hex post would bottom out.
This is how I have the corners.
It's the clear shield, the black 1/4" spacer, 2 washers, and the hex post. That all locks down nice and tight.
The two posts in the center of the old DMD have 1/4" spacers, and one of the original DMD nuts to lock them.
Finally, the speaker wire is attached tightly at all 3 points it was before on the bottom of the old DMD using the mount screw for the DMD driver board that I didn't need because it was already a 5v DMD.
So I didn't see anywhere I could get new rattles. But I'll let you know once I get the shaker I ordered.
