We're back!
After a disaster in our datacenter took down our server, we are now running Pinside on a brand new server. However, things may not work as expected as we are still polishing the playfield and adjusting some switches! We might be switching to maintenance mode a few times. Please see this forum topic for more info.
(Topic ID: 50762)
Metallica owner's thread
By swampfire
7 years ago
  • 18,402 posts
  • 1,030 Pinsiders participating
  • Latest reply 1 day ago by SkyKing2301
  • Topic is favorited by 375 Pinsiders
5 key posts have been marked in this topic (Show topic index)
There are 18402 posts in this topic. You are on page 233 of 369.
#11601 3 years ago
Finally took a few min to level my machine. It's been in a temporary home in the garage till my basement is done being remodeled. Since I brought it home it, the back of the machine has been way high. I leveled down today and wow...it's like a snail now. At least I can finally put up some decent scores now though.
#11602 3 years ago
Quoted from davids1024:
This is the board that came in addition to the shaker motor board
This board is very important and needs to be installed on the CPU/sound board. Remove J3 connector and plug this into J3 and reinsert the connector onto this pcb. This pcb filters any line noise generated by the shaker motor that will interfere with your switch matrix.
#11603 3 years ago
Quoted from bent98:
Just wondering if the snake jaw is supposed to be flush with the PF? If so, how do you adjust?
Here are some pics of my snake with the jaw open.
The only way I could adjust mine was to remount the snake assembly with spacer washers between it and the playfield.. Mine was a lot higher than yours with the mouth open.
Quoted from gweempose:
I don't own a premium/LE, but isn't there a screw underneath to adjust the height?
There is an adjustment screw on the jaw latch coil assembly. Some say adjusting it helps, but for me it made no difference. Looking at the design, I don't think it was intended as a height adjustment.
Rob
#11604 3 years ago
Quoted from Meph:
I added my custom topper tonight. I pre-ordered the Metallica Pops! as soon as I saw they were coming out. My only disappointment is that they aren't bobble heads, instead they are fixed. I was hoping for the headbanging when the shaker fires I plan to add an led strip below them and facing them to give a spotlight effect. Will see how it comes out.
I had my eye on these when they announced them.l and was planning on doing the same. They look good! I should probably just order the set now.
#11605 3 years ago
Quoted from Rob_G:
Rob
Same for me as well. That screw didn't adjust the height so I used washers. Still sits a bit higher than the PF but much better than before.
#11606 3 years ago
Quoted from Meph:
Just got the same ones for my topper! Looks good.
#11607 3 years ago
Quoted from sohchx:
Question, if I hit the ball to the top into the upper left lane, can I hold the left flipper down like you do to drop that plunger when shooting for the skill shot, and will that plunger then drop allowing the ball to travel completely around the upper arch exiting the upper right lane?
Nope, it only keeps the post down if you do it on the plunge, not during the game.
#11608 3 years ago
Quoted from Rob_G:
Rob
Looks like the screws to take out the snake are a bit stripped from the factory. I rather not open Pandoras box. How is the height of your snake in relation to mine?
#11609 3 years ago
So i got the magnet fixed for the coffin
Lock - now the hammer seems somewhat out of sync - any ideas? Thanks
#11610 3 years ago
Quoted from bent98:
Here's pictures of mine both open and closed. The glass was on so there's a bit of reflection, but you get the idea. I think yours is fine and doesn't need any adjustment.
Rob
#11611 3 years ago
I've tweaked my design for the mod on the cross insert for Premium/LE. Installation requires loosening of the subway, but I've tweaked it so you shouldn't have to remove it completely.
So for those that are bothered by the excess light surrounding the Crosses, here's your mod (https://goo.gl/3F7d31). Orders placed today should go out tomorrow, otherwise, the rest will go Monday.
New design
#11612 3 years ago
Anyone else here have cratering going on in front of Sparky? Just noticed it on mine yesterday
#11613 3 years ago
Quoted from damageinc55:
his new version is incredibly well done. I've worked with damageinc55 to help him perfect his design for the premium/LE machines and he's nailed it
#11614 3 years ago
Quoted from j_m_:
And the Pro version remains great! I really notice it on unmodified games now.
#11615 3 years ago
Quoted from monkeyboypaul:
Got on them on my pro. Why not? Cheap mod, easy to install, and looks so much better. You forgot they are there but when you see a game without one - eww. Same for colordmd. When I see a game with the stock red dmd it just looks so awful.
#11616 3 years ago
Stern was hacked see link for details and how to safe guard your computer and identity.
https://pinside.com/pinball/forum/topic/stern-hacked-do-not-open-invoice-emails-from-stern#post-3975943
#11617 3 years ago
For those who have done it... how hard is it to replace the magnet core in front of Sparky? After a few hundred plays, my Met Pro machine is starting to show some dimpling and mushrooming of the metal surface. It's a cheap enough part to replace, but that is a BIG nut on the bottom of the assembly under the playfield and I am guessing it is not going to be very easy to get it loosened up.
#11618 3 years ago
Quoted from parsonsaj:
Super easy but I also went and bought a socket to fit the nut (if memory servers me correctly I think it was 3/4 inch but I could be wrong).
You can do it with a wrench but I felt no reason to risk damaging anything especially since their are more than one magnet on the game (plus I had other games with them).
#11619 3 years ago
Very easy to loosen the nut and if you don't have a socket, just use vise grips.
#11620 3 years ago
I found these skulls while walking thru the Holloween section of ace hardware today, only $5.99 each. I am not sure exactly what I plan to do but they are going to be part of my Metallica topper. Does anyone have suggestions?
#11621 3 years ago
Cut out the eyes big enough for red mini domes to come out from behind and put red flex head bulbs behind them to light up. Or use 12v red flex head and tie them into the left right flashers.
#11622 3 years ago
Do you have the light part numbers and where you buy them? I have done a lot of mods but have never built ones from scratch
#11623 3 years ago
Just go to Marco and look up mini domes and chose your color then look up sockets for flashers. Here's what I made for a couple of T2 bb stickers for my game room, 6.3v then used a 6v wall wort to power them.
#11624 3 years ago
That board connects to you J3 in your back bock....I installed this as I am having problems with my shaker motor...if the shaker motor is off the game works perfect the coffin magnet works 100% every time turn the shaker motor on and the coffin magnet will let go of the ball not every time but probably 3/5 times which is shit. So the distributor sent me this as he thought it was a "noise" interference as in a electrical noise but it still didn't fix my problem...I have a stern rev a shaker motor and im
thinking I need to try a rev b shaker...what do you guys all have rev a or rev b ?
#11625 3 years ago
Quoted from embryon:
I need some advise please. Just installed a Stern shaker kit on my metallica premium and having major problems with the hammer magnet and coffin feed. Most times the ball will dislodge from the hammer magnet when the shaker activates and a few times the ball had jammed trying to enter the coffin lock. While shaking its offsets the ball to the right of the coffin path and the jam when the magnet coil tries to go up to the playfield.
It seems like the magnet is not strong enough to keep the ball on its path both prior to the hammer coming down and if it succeeds there, entering the coffin lock is compromised.
Any suggestions?
I have had the ball release on the sparky magnet a couple of time too. I have tried all three settings moderate, minimal and maximal and the only mode I have had fault free games is setting 'None'
Same problem here mate, my machine is a met premium monsters and running the stern shaker rev a.
I don't have any problem with when it drops it goes in fine but the problem is making it stay on the coffin lock the only time I will have faultless play is when the shaker is off otherwise it will fault every time which is really sad
#11626 3 years ago
Have you tried to set the shaker motor to minimal use?
#11627 3 years ago
Quoted from NEOZATZY:
i might be wrong here, but I thought Metallica used a Rev B shaker?
#11628 3 years ago
Is this a new record time for breaking Sparky's foot off?
39 days and under 100 plays.
#11629 3 years ago
Quoted from EEE:
Crap, I've never seen it happen before.
#11630 3 years ago
Quoted from EEE:
Merely a flesh wound.
Certainly not starting off on the right foot!
Sorry, couldn't help myself. Was it a clean break so that it can be glued back together and not noticeable?
#11631 3 years ago
Quoted from EEE:
I recently went through every image in the gallery for this thread to catch up, and there are photos of wear, but never a break.
Claim manufacturing defect and request a replacement!
#11632 3 years ago
I've already contacted JJ at Gameexchange of CO, and he is taking care of it. Top notch customer service for sure.
Quoted from Neal_W:
#11633 3 years ago
Quoted from EEE:
When I bought mine NIB it had a slight flaw in the same left foot of Sparky, not even a crack, I sent a photo to Stern, they sent a replacement no questions asked.
#11634 3 years ago
Anyone here have the TotalLightshow mod on their pro?
I got mine installed today and none of the GI works...
Trying to find any basic troubleshooting or how to set the thing into test mode.
#11635 3 years ago
Quoted from GrimDog:
Check the small fuses on the Lightshow boards. I've had one blow and I think extra fuses are included with the kits.
#11636 3 years ago
they look ok to me
#11637 3 years ago
they look ok to me
If you have a multimeter, just test them to be sure. Maybe you get lucky.
#11638 3 years ago
Shit I got a short somewhere
Replaced the top fuse and it lit up for a few then died.
#11639 3 years ago
Also, anyone have a picture of his connection on the board? I knocked the damn wire out of the connector
#11640 3 years ago
I have it. It is INCREDIBLE. It sounds like you didn't hook some of the wires up correctly in the back box. Refollow the video steps to see what went wrong.
EDIT: oops. I see what happened. Sorry man. Seriously, with this mod, I honest to god see no reason why you'd spend an extra 2k for the premium. It just doesn't make sense.
#11641 3 years ago
Quoted from Sk8terRIP:
yeah I have tried it on minimal, it does make it better and doesn't fault as much but I don't like paying $250 for the shaker to only half work as I might as well play the machine with it off as it has such little effect set on minimal.
#11642 3 years ago
Quoted from Lermods:
That's what I thought too, the one that came in the machine installed from the distributor is a rev and but all the ones I have seen for sale are rev b, I have brought this up with the distributor and he is enquiring with stern. But I don't know if the rev b is for the original run of machines and the rev a is for the new run
#11643 3 years ago
No doubt bandit will help you find the problem.
#11644 3 years ago
Quoted from Neal_W:
Mine had this happen, but it has 2500 plays on it. Same type of break. Though on mine the broken foot stuck to the playfield so I really didn't need to do anything. Most people don't even notice. Shit, I didn't notice when it happened. I just looked one day and "oh, well then...."
#11645 3 years ago
Quoted from mrgregb123:
Yep. Exact same scenario for me. Foot stuck under and not moving, but broke long ago. Doesn't affect play and not noticeable unless you're looking for it.
#11646 3 years ago
Hey guys,
My snake has a broken fang. Has anyone found a way to glue or reattach an original fang?
#11647 3 years ago
Quoted from Hougie:
Hey guys,
Honestly if that happened to mine I would just buy a new set of fangs. I don't remember the price but I don't remember them being outrageous or anything. I think if you glue it back on it'll just break again soon. Definitely worth a shot though! I would reach for the handy dandy cyanoacrylate (CA) glue.
Edit: love the Eddie avatar btw haha
#11648 3 years ago
Quoted from Hougie:
Hey guys,
I don't believe there are any "original fangs" . The snake arrives toothless and looking like a turtle until it is modded.
#11649 3 years ago
Quoted from Hougie:
Hey guys,
Is your MET one of the original ones that had the snake fangs from the factory?
#11650 3 years ago
Quoted from yzfguy:
Mine were on from the factory. They are (were) attached to the upper portion of the head.
Quoted from HankScorpio:
Yes. Mine is an early run. Pre toothless lizard.
