so much arm twisting I'll throw it in my cart for my next PBL order
Quoted from S37VEN:How integral are the pops to the rule set and how often is the post enabled during gameplay?
Both the pops and the top lanes are very important if you want to maximize your score.
Quoted from gweempose:Both the pops and the top lanes are very important if you want to maximize your score.
I also find that hitting the orbit shots that flow all the way through during a combo feel much more satisfying compared to disabling the diverter and having every orbit shot go all the way around...It's the little things.
Quoted from PinballNewb:I also find that hitting the orbit shots that flow all the way through during a combo feel much more satisfying compared to disabling the diverter and having every orbit shot go all the way around...It's the little things.
Agreed. The pops are active on this game so disabling that up post is lame. I like to get the whole game involved.....not 95% of it
Agreed. I like playing the game as designed. Replacing the post is easy and cheap. A must for every ownee. Stern should of shipped with a metal post but that is just one of many cut corners.
I had no idea the post was supposed to stop the ball from the left orbit and deposit it in the pops. I'll be ordering the metal post for sure.
Quoted from damageinc55:But how often is it stopped vs. getting bounced back? That's what the metal post fixes.
For me, I went from 75% plus bounce backs to maybe 1%. It was that drastic...
I would be happy with a 75% rebound. In nearly 100%. Need to finally get this ordered
I was more like 95 percent bounce backs with factory post. Now maybe 10 percent bounce backs at the very most with metal post. I super hard clean shot can still bounce back. But thats acceptable to me.
Ok, just had league at my house. Ya I now have a handful of left orbits going back to the orbit. Blah, time for a pbl order
I have achieved beating all the high scores on my game except for eotl and combo champ.
I don't seem to even get close to to 20 combos. Is this normal or do you guys score lots of combos per game?
Quoted from embryon:I have achieved beating all the high scores on my game except for eotl and combo champ.
LOL I am lucky to get 4 or 5 in a good game... 20 seems to be the stuff of fiction!
For something like that, I only play to do that one goal. Otherwise last night I don't think I hit the ramps much :/
Quoted from northvibe:For something like that, I only play to do that one goal.
I've started a lot of games thinking that way, then quit after about a minute and two brick/drains
Quoted from damageinc55:I've started a lot of games thinking that way, then quit after about a minute and two brick/drains
hahaha...yeah. patience is key or take the glass off :-p
I saw the Guns/Metallica show at the Metrodome in Minneapolis. The ticket was $34, which at the time in 92' was very expensive. That's about half of what a shirt at a concert costs these days.
Quoted from Minneapolispin:I saw the Guns. The ticket was $34
I agree. I saw GnR in '91 same "Use your Illusion" tour only Skid Row opened. My buddy went to see Guns last summer ... $900. per ticket. Crazy!
Quoted from Dee-Bow:By custom do you mean home-made?
I made it at your Mom's house. Does that count as home made?
If anyone is interested in making the Metallica topper, I have the figure and stage set. I never opened it and can't use it as I only have 9 inches of clearance above my machine and you need 12 for this. I paid $60 with the shipping but I'd be willing to ship it anywhere in the US for $50.
Quoted from bent98:I am having issues about 25% of the time with launching the ball into the orbit. It happens with auto launch or hand launch.
Sometimes it hits the side of the rail before its exits.
Looks like the ball isn't being driven 100% straight each time. Step one is the remove the cliffy's in the shooter lane and reattempt. When the cliffys elevate the ball off the shooter lane, all kinds of crazy things can happen. They have to be in there just right to protect but not cause the ball to go nuts.
I'd try that first.
Good luck moving that trough side cliffy after it's installed. The adhesive is strong and any bend upward in the cliffy will eventually pop back up.
Quoted from snakesnsparklers:Good luck moving that trough side cliffy after it's installed. The adhesive is strong and any bend upward in the cliffy will eventually pop back up.
The newest ones have that problem resolved. It's just a tiny metal tab that drives up into the rail to keep it in place. Quite ingenious. Of course the V1 just used the pressure to keep it in place, unfortunately mine would always work their way into the shooter lane causing things like the above post and much much worse including launching it like a catapult into the glass.
Look straight down at the ball and manually push in the launch solenoid slowly with your finger. You want to see the two sides of the launch "fork" contact the ball at the exact same time. I recently had to bend mine after it had worked perfectly for thousands of games. If it needs bending, you'll have to take the entire mech apart and use some very strong set of pliers, or a vise. That is some very strong steel!
Quoted from LOTR_breath:Look straight down at the ball and manually push in the launch solenoid slowly with your finger. You want to see the two sides of the launch "fork" contact the ball at the exact same time. I recently had to bend mine after it had worked perfectly for thousands of games. If it needs bending, you'll have to take the entire mech apart and use some very strong set of pliers, or a vise. That is some very strong steel!
He says it's also happening with a manual launch. That would steer it to something that could affect either type of plunge. I've definitely seen this as well though which was indicated by it plunging very differently between auto and manual.
Quoted from gweempose:It prevents balls from bouncing back down either orbit.
I still get 90% bounce backs with the metal post. I just disabled the post on the settings. I don't get near the pop bumper action but I think it is fine.
Quoted from kcZ:I still get 90% bounce backs with the metal post. I just disabled the post on the settings. I don't get near the pop bumper action but I think it is fine.
You hear of this from time to time, where the metal post doesn't fix it. I wonder if it's a pitch thing. Are the machines that aren't fixed by the metal post set up steeper than usual perhaps?
Quoted from TimeBandit:You hear of this from time to time, where the metal post doesn't fix it. I wonder if it's a pitch thing. Are the machines that aren't fixed by the metal post set up steeper than usual perhaps?
Either that, or they are using a different metal post. The one I installed, which I believe is also the one that I linked to above, has a slightly smaller circumference than the the stock plastic post. I believe this creates a little more "give" when the ball strikes it, thus helping to absorb the inertia better.
My hammer magnet was stuck on and getting super hot. After some pinside reading, I found the white resistor in the cabinet from the magnet board. Tried resoldering and resinstalling but it didnt work. Guess I'll be calling Stern on the 5th. Please say a prayer for my MET. Thank you.
Quoted from bdaley6509:My hammer magnet was stuck on and getting super hot. After some pinside reading, I found the white resistor in the cabinet from the magnet board. Tried resoldering and resinstalling but it didnt work. Guess I'll be calling Stern on the 5th. Please say a prayer for my MET. Thank you.
Unless your game is still under warranty, Stern probably won't be much help, except for maybe a little technical advice. Here is the part you need. $65 plus shipping.
Quoted from LOTR_breath:Unless your game is still under warranty, Stern probably won't be much help, except for maybe a little technical advice. Here is the part you need. $65 plus shipping.
http://www.pinballlife.com/index.php?p=product&id=4029
Linky no worky
Quoted from yzfguy:Linky no worky
That happens when an item sells out on Terry's site sometimes. It looks to be sold out pretty much everywhere. I'd go through my distro and have them order it.
http://www.marcospecialties.com/pinball-parts/520-6801-00
http://www.sternpinball.com/service-bulletins/service-bulletin-182-metallica
Damn. If I have to remove that I may kill the metal and have to but a new one. I guess I will have to do some more testing to be sure before I actually attempt..
When I first got the machine I noticed the auto launch screw that holds the mechanism was extremely loose. I tighten that up and it help the auto launch by about 25% but both auto launch and hand plunge are still too inconsistent.
Quoted from bent98:Damn. If I have to remove that I may kill the metal and have to but a new one. I guess I will have to do some more testing to be sure before I actually attempt..
The auto launcher on mine screws up sometimes and starts binding up...You take it apart and put it back together and it helps for awhile.
Phoebe
if you do attempt to move the cliffy, try this as it worked for me. I used fishing line to slip under the front edge of the cliffy and then kind of sawed downwards to break the seal. No damage whatsoever, but use strong line. Make sure you move sideways and not put pressure upwards to avoid damaging the cliffy.
I use this method to remove side rails but use wire in that instance
Quoted from embryon:if you do attempt to move the cliffy, try this as it worked for me. I used fishing line to slip under the front edge of the cliffy and then kind of sawed downwards to break the seal. No damage whatsoever, but use strong line. Make sure you move sideways and not put pressure upwards to avoid damaging the cliffy.
Now that's a good idea.
Ok, thanks for the tip.
I sent my pic over to Cliff and here's his response:
argh. they installed it too low on the right one. I designed them to look symmetrical and sit straight across from each other. I know what happened. They used the lower screw hole on the right strip. Its only there for games that need it- IM, SM and a few others. On metallica its not needed. if you line it up across from the left side parallel it will miss the lower screw hole but thats ok, it will still be clamped and hold. Being installed too low like that cocks the ball to one side a bit. Look at the pic of mine and you'll see the top edge of both protectors line up with each other. Mine install on top and his on the bottom. I am glad I dont have to take off the left side. I will make the adjusment and see what happends. Funny thing my TWD and ghostbusters all have them install incorrectly. I guess I will have to fix them all.
Even in this video on how to install it's off. Fast foward to the 39th second.
I am at a loss. I tried putting some washers on the plunger to move it back abit, I tried bending the auto launch to make better contact with the ball. Same issue. . I am looking at the metal fork ramp and it doesn’t look center with the ball cavity. See how the arrow of the play field isn’t center with the metal fork. Its shifted slightly to the left. Is that normal?
Quoted from bent98:I am at a loss. I tried putting some washers on the plunger to move it back abit, I tried bending the auto launch to make better contact with the ball. Same issue. . I am looking at the metal fork ramp and it doesn’t look center with the ball cavity. See how the arrow of the play field isn’t center with the metal fork. Its shifted slightly to the left. Is that normal?
I couldn't get a good look at where your shooter tip is compared to the ball at rest. For some reason the Stern shooter rods are a bit shorter than most. I have replaced most of my shooter rods on my Stern games to get the tip of the plunger touching the ball at rest. If it isn't touching, the shooter rod has to go past its resting point to get any force on the ball. Which makes it a very weak plunge. Swapping out the shooter rod with any aftermarket one makes the plunge so much simpler. If it is the auto launch mech that is giving you fits, there are a lot of threads with fixes for that.
Here is a picture of my stock Iron Man shooter rod next to the new one I bought, a bit of difference in length.
This page was printed from https://pinside.com/pinball/forum/topic/metallica-owners-thread/page/222 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
