(Topic ID: 198056)
Metallica owners I need some help.
By Jeff_PHX_AZ
6 years ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by Pin_Guy
    #1 6 years ago
    My magnets stopped working. Fuse LED light out on F5, F7, F8, F10. That's right 4 blown fuses. F7 is for magnets, but not sure coil and flasher lamps fuses would blow. They all work, just magnets don't. What happened was ball got hung up on coffin magnet and never dropped and came back up still stuck on magnet, then all magnets stopped. Game appears to play even with the blown fuses, just no magnets. Any idea why 4 fuses would blow. This is the second magnet board in this game since 2014. I'M the original owner. Ism hoping it's not the board again . I have not check anything except pull backless and saw all the led lights out on the 4 fuses. Thanks
    #2 6 years ago
    Replace F7 and close your coin door?
    #3 6 years ago
    Quoted from Pin_Guy:
    Yep. It's a 4 or 5 amp Slow Blow.
    #4 6 years ago
    Its a 4a slow blow. Ok, but what about the others? Replace F7 brings them back to life? F5 , F8, and F10 is out, mot sure why they would go as they are coil and lamp flasher fuses and coils and lamp flashers work.
    #5 6 years ago
    Check the magnet board to see if a white resistor fell off it and down into the cabinet.
    #6 6 years ago
    Quoted from Jeff_PHX_AZ:
    You said you had not checked anything other than look at the lights, so you are assuming the fuses are blown because the lights are out, but the lights don't signify that a fuse is blown, they tell you that there is no power at those points. Those are interlocked which is why I said to close your coin door as your coin door will remove power to those voltages and make the lights go out.
