(Topic ID: 245044)
Metallica LED
By miztar
2 years ago
  • 11 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by miztar
    #1 2 years ago
    I recently got a Metallica Pro from my local dealer and about a week later I see that a red spider LED and one upper bumper LED are both not working. I am very new so just wondering if anyone could point me in the right direction for how to fix these?
    #2 2 years ago
    If you bought it from a dealer a week ago I would reach out to them to start. If the dealer is no help someone here will chime in to get you started.
    #3 2 years ago
    All metallicas are actual LED bulbs correct? You need to change the lightbulb.
    Now, how many Pinsiders does it take....
    I am ASSuming you tested all lights in the menu to confirm they do not work?
    #4 2 years ago
    Quoted from TheLaw:
    I did test in menu.. those the only 2 and yea the machine should be all LED. Thanks!
    #5 2 years ago
    Quoted from miztar:
    What I meant is are they bulb LEDs or boards. If bulbs...
    Lift the PF up, jiggle the socket (spider insert) around and see if they work in test after. Look for missing/detached wires.
    Just swap a bulb out out of any close socket and see if it works. order new bulbs after
    Pop bumper bulb you're going to have to go in from the top, which may be blocked by ramps and god knows what else.
    #6 2 years ago
    Quoted from TheLaw:
    They all bulbs I believe.. what is a board LED? Thanks
    #7 2 years ago
    Quoted from miztar:
    Newer games have printed circuit boards with the leds on them...not bulbs that you can easily change
    #8 2 years ago
    Quoted from TheLaw:
    Oh man, I read it as the bumper stopped working not just the light.
    #9 2 years ago
    Quoted from TheLaw:
    Ahh, this one looks like lots of bulbs you can replace so I’d imagine it’s just the led bulb... I’ll try moving one on it and see if it just out. Thanks for the help
    #10 2 years ago
    I don't think MET has any board leds. My MET has a few insert bulbs that like to wiggle loose or have loose connections. You probably just need to push the bulb back in or adjust the bulb wires. If you bend the wires out like a 'V' it helps them make contact better. If none of that works, try to put the bulb into another location and see if the bulbs lights there. If not, the bulb is bad and easy to replace - should be a 2smd cool white wedge bulb. Look up videos on how to raise and lower playfield if you are not familiar with that. It's really easy. Just don't do any work with tools with the power on.
    You should be able to access the pop bumber led from removing the cap (top part) of the pop bumper. There should be a couple of visible screws holding the cap on. Same thing, wiggle it around and push the bulb into the socket.
    #11 2 years ago
    Quoted from jawjaw:
    Thanks man! I’ll give it a shot
