Yes this worked great. I haven't had a problem since.
mine was getting so bad , the ball would be held for a second , drop off , then the hammer would come down . meanwhile it held it long enough for it to cease moving, letting it drop straight down the middle. it was horrible.
Post edited by freezie: spelling
Quoted from freezie:mine was getting so bad , the ball would be held for a second , crop off , then the hammer would come down . meanwhile it held it long enough for it to cease moving, letting it drop straight down the middle. it was horrible.
Sooooo Glad i did not Post this for Nothing Soooo Happy to Help Pinsiders
Mine also has been Pefect since i did this
Quoted from thunderking50:Get the New Board.
Get the software 1.6 in there.
and in the game settings Number 89 default is yes....Set this to NO
This Fix works Perfectly for everyone i helped and the freakin Hammer is awesome !
You rock thunder king! After a month with my Metallica, I started having awkward hammer issues. This adjustment seems to have improved it to a 95% consistency which is great ! Thanks for posting this.
Quoted from Eskaybee:You rock thunder king! After a month with my Metallica, I started having awkward hammer issues. This adjustment seems to have improved it to a 95% consistency which is great ! Thanks for posting this.
Yaaaaaa Makes me Happy
Iam gonna have to try that setting on my premium, I had a few phantom hits, but only a few. Game setting #89 set to NO, ok will change when have machiune on again. Any other tips for the adjustment in settings? Some of the settings I have no idea, like the "abort animations" its on ONE what does it do? Thanks
Hi
I have s Brand new Premium
Sonstiges the Phantom Hammer Magnet
What Shorts i so
Setting 89. ?!?! To yes ???
Its disable the Magnet ?!?!
Thx
Tom
Quoted from kapsreiter:Hi
What Shorts i so
Thx
Tom
set it to no,factory is yes
Any update on this? How has everyone's hammer been? I updated code and changed some songs... Phantom hits came back. I went to change #89 but the default on that is now NO... Has the adjustment number changed for the hammer? Is it number 90 now that needs to change from YES to NO?
Quoted from pinchamp:Any update on this? How has everyone's hammer been? I updated code and changed some songs... Phantom hits came back. I went to change #89 but the default on that is now NO... Has the adjustment number changed for the hammer? Is it number 90 now that needs to change from YES to NO?
Tried swapping boards yet problem persists here.
Have been running 1.64 software and tried two replacement opto boards to no avail. Setting #89 is set to no by factory default. Tried swapping balls and that didn't help. Finally, turned shaker motor off and all the sudden, magnet works 100% now. So played a handful of games concentrating on nothing but hitting the coffin to test the magnet. I made scores of $163M and $154M, pretty respectable imho. This game is so much more fun when the hammer works. I was at my wit's end with the phantom hammer - but no more.
Anybody else resolve thier hammer issue in this manner? I might try engaging shaker less frequently, but if it mucks with hammer consistency its back to off.
Quoted from jeffspinballpalace:Have been running 1.64 software and tried two replacement opto boards to no avail. Setting #89 is set to no by factory default. Tried swapping balls and that didn't help. Finally, turned shaker motor off and all the sudden, magnet works 100% now. So played a handful of games concentrating on nothing but hitting the coffin to test the magnet. I made scores of $163M and $154M, pretty respectable imho. This game is so much more fun when the hammer works. I was at my wit's end with the phantom hammer - but no more.
Anybody else resolve thier hammer issue in this manner? I might try engaging shaker at less power, but not if it mucks with hammer consistency.
This is very interesting. I have shaker ands met working fine. I wonder if there is something loose on yours that causes the shaker to register hits.
This reminds me of the flipper jitter issue I was having with my STLE anytime the shaker was supposed to fire and failed it would cause the flippers and flashers to jitter. The fix for me was replacing the shaker board and wiring associated with it including the long 1-wire that goes to the back. So I'd look into replacing everything associated with the shaker motor.
Quoted from Troutfarm:I have had no issues with the hammer with 1.70 defaults.
Awesome
Explain "fantom hits"? I think mine is doing this now....
After the first activation of coffin lock, the hammer keeps activating, as if there is a ball on the magnet when there isn't. I have not updated the latest code yet. What is the fix for this?
What feature adjustment number is this with the 1.7 code? Is it #93? "coffin mag. detect/cap.b. hit"? Factory default is "off". Does this mean that if it was set to "on" the magnet would detect with every captive ball hit or just a captive ball hits when lock is lit? My game is only a week old and I had 3 phantom hammer strikes the other night.
"Get the New Board"
What's the new board?
gliebig, I am having the same problem as well my machine is the premium monsterds brand new June this year, I have a shaker motor installed and it appear to be the shaker motor some how if I use the shaker motor I get the phantom hammer every game I pay if I turn the shaker off in the settings it will not fault at all so im not sure what the problem is, I have replaced the shaker motor, the shaker motor pcb, the magnet pcb also installed the "line filter on j2" in the back board.
My question to you is do you have a shaker motor installed?
Anyone else have any ideas.
This is a brand new machine out of the box, home use only and I have also done a factory reset and reinstalled the 1.70 firmware any help would be appreciated.
Neozatzy, had the same issue , go to game adj
#126 and set shaker motor to minimal use, you still get a good feel with the shaker motor and magnet works perfectly now on mine
Mine has been working pretty good now. I still have to get a slower indirect shot for the magnet to grab the ball, which I guess seems to be pretty normal. Wonder why they didn't make the magnet grab stronger like the Sparky mag?
Quick update for the MET's that are still not updated with the new board and on the newest firmware 1.80;
So if you have a version C or lower hammer-board, buy a version D. Do a firmware update to 1.80 and do not change any setup. The presets for update 1.80 has are already ok, the hammer work perfect, no changes to do eg do not change anything (all above is also for older firmware.
I had a 1.23 MET with the version C board. Updated to 1.80 -> terrible !! Then changed version C to version D -> excellent
Quoted from JvdS:Quick update for the MET's that are still not updated with the new board and on the newest firmware 1.80;
Where do I buy a version D board. I just got my premium and the hammer doesn't seem to work.
Is this the correct board?
https://www.marcospecialties.com/pinball-parts/520-6801-00
This page was printed from https://pinside.com/pinball/forum/topic/metallica-hammer-fix/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
