(Topic ID: 127717)
Metallica: flippers go dead for few seconds
By Cenobyte
8 years ago
  • 11 posts
  • 4 Pinsiders participating
  • Latest reply 8 years ago by tktlwyr
#1 8 years ago
My Metallica LE is having a strange problem that only shows every once in a while. When playing, the flippers go dead for a few seconds just like when somebody opens the coin door. It lasts a second or so, sometimes a few seconds, and you can continue with the next ball after that.
Somebody suggested recent Stern pinballs have a problem with the opto in the VUK of the ballthrough, but could that lead to dead flippers? I would think there was a problem with the coindoor circuit?
Any tips or similar experiences?
#2 8 years ago
There are two idc connectors (one on each side) of the ball trough that have a tendency to loosen. That can cause the game to think that the balls have drained. So it does the end of ball sequence (dead flippers) and kicks u out a new ball.
You have to just push them back on snug every once in a while. I do it every time i have the playfield up.
#3 8 years ago
Or you could simply replace these connectors with Molex connectors and trifurcon pins.
I've had 3 newer Sterns with this issue. I've replaced the connectors as mentioned above and have never had the problem return on those machines.
#4 8 years ago
Quoted from Rickwh:
Would putting a couple of wraps of electrical tape on them work too?
#5 8 years ago
Quoted from MustangPaul:
It has nothing to do with holding the connector on. It has to do with the "electrical" connection between the IDC connector and the header pins on the opto board. The trifurcon crimp on connectors grab the opto board header pins better and the CPU doesn't see a loss/drop of the electrical current. This loss/drop is what signals to the CPU to end the ball.
#6 8 years ago
So it's a bit like the problem with eddy sensors on machines like RS and TOTAN? These also have connectors that have the tendency to deteriorate and cause problems. I solved these by soldering the wires straight on the connectors. Wouldn't that be better to do here as well? Apart from the fact that it's a bit sloppier than a Molex/header solution of course...
#7 8 years ago
Quoted from tktlwyr:
I see, thanks.
#8 8 years ago
Tktlyr, do you have a parts list and links on where to get them?
#9 8 years ago
https://www.greatplainselectronics.com/products.asp?cat=80
https://www.greatplainselectronics.com/products.asp?cat=86
Don't forget a crimper!
There's a thread on the forum discussing ratcheting crimpers. Search it out and spend the extra $10. From someone who has replaced a bunch of connectors, a good ratcheting crimper is worth the investment.
#10 8 years ago
So i have little exp with this, so bear with the dumb questions...
Basically you are saying to.
1 remove the idc connector.
2 strip a bit of the insulation off wires running to trough on each side
3 crimp on the clips to each wire
4 put the clips/wires into new molex
5 slide the molex onto the existing pins on trough
So no modification is needed to the trough side?
And these dont vibrate off? Even with a shaker?
#11 8 years ago
Your procedure is correct.
No modifications to the trough.
They don't vibrate off. Even with a shaker.
11,000 (OBO)
Mount Pleasant, WI
$ 29.95
Professor Pinball
10,000 (OBO)
Middletown, DE
$ 19.95
SilverBall Designs
$ 69.99
$ 69.99
Filament Printing
SilverBall Designs
$ 9.99
Bent Mods
$ 24.00
Pin Monk
$ 64.00
Lighting - Under Cabinet
$ 69.99
$ 79.00
Arcade Upkeep
$ 200.00
Professor Pinball
YouBentMyWookie
10,600
$ 1.00
Mitchell Lighting
SilverBall Designs
$ 7.00
Pinball Z
$ 25.50
arcade-cabinets.com
$ 69.99
SilverBall Designs
11,600 (OBO)
Lubbock, TX
$ 22.50
This page was printed from https://pinside.com/pinball/forum/topic/metallica-flippers-go-dead-for-few-seconds and we tried optimising it for printing. Some page elements may have been deliberately hidden.
