(Topic ID: 116519)
Metallica coffin Magnet core leveling
By Drewblood419
9 years ago
#1 9 years ago
I just installed the Newton ball in my Metallica LE since then it plays awesome but I am getting some air balls off of the Newton ball Mostly shooting it over the grave marker targets I even had one land on the left ramp wire form (which I must admit was kind of cool LOL) I think what is causing it is that my magnet core is very very slightly above the playfield not enough to really notice but if I run my hand over it I can feel it and what I'm wondering is if it is catching air just enough to make contact with the upper side of the Newton ball causing it to ricochet up and over the grave markers, from looking at the magnet mechanism it looks like there are four bolts that could add just the leveling of the plate on the side of the mechanism itself or would it make more sense to adjust the magnet core by loosening the big but on the threaded portion of the core and pressing it more firmly down onto the magnet plate itself has anyone adjusted the level of the magnet core on Metallica LE or premium any info would be much appreciated
#2 9 years ago
My game has the same problem so I put the block back in place rather than messing with the magnet level. The issue with my game is that the magnet core is slightly crooked. If I level 1 side, the other side might not be as level. Besides it might be a PITA to adjust anyhow so I won't attempt.
Rob
I would like a new block, but one that has a slight down angle on the face to it to keep it from airballing into the back of the hammer.
#3 9 years ago
Really leaning towards loosening the magnet core nut tapping the magnet core on the top down more flush with the plate on the magnet itself and then retightening the bolt
#4 9 years ago
I have the newton ball & Cliffy's protector around the mag hole. Hasn't been a problem on my LE.
#5 9 years ago
you don't want to level this magnet, it pushes down when the ball rolls over it. Do you have some sort of cliffy there? if so that's the problem.
#6 9 years ago
Thought about placing a small washer under the Newton ball (between the ball and the plate) and between the bracket posts and the plate to raise the ball up a bit and see if it helps reduce the air ball issue last night one flew against my mirror blade and dented it yikes lol
#7 9 years ago
Quoted from Breadfan:
Interesting. I had the same setup and was getting tons of airballs. I removed the Cliffy and all is good!
#8 9 years ago
Quoted from Drewblood419:
I tried that and it didn't help.
Rob
#9 9 years ago
Quoted from dgposter:
How about posting a picture of how level your coffin magnet is? If you put a flat edge across the playfield, does it push the magnet down even slightly?
Rob
#10 9 years ago
Rob...when I put a flat edge across the magnet it does go down very slightly. I'd say about 1/32 of an inch.
#11 9 years ago
Okay so I think I found the problem and a temporary or possibly permanent solution for the magnet not being level it looks like the threads of the magnet core where it meets the stop plate is where The level issue is coming from my magnet core is slightly angled even though it is tightened down flush with the plate my father a retired machinist took a look at the whole assembly last night and while we could adjust the level with the bolts on the side of the mechanism that seemed like a giant pain in the butt and I would worry that it would cause more problems than it would help so what we did was to make a small split washer out of a sheet of brass we punched out the ID and the OD cut the washer and fit it around the shaft above the existing washer that stops the plunger coil which lowered it about a sheet of paper thickness and made the core perfectly level with the playfield I played about 15 games last night with not a single airball whereas before I would have one at least once or twice per game I will try to post some pictures when I get home this evening so far so good
$ 29.95
$ 1.29
Daddio's 3D Printed Mods
12,250 (OBO)
Bradenton, FL
$ 68.50
$ 7.00
Pinball Z
12,500 (OBO)
West Chicago, IL
$ 26.50
$ 69.99
$ 9.95
Mitchell Lighting
$ 9.99
Bent Mods
$ 200.00
Professor Pinball
$ 160.00
Sparky Pinball
$ 12.95
$ 69.99
$ 120.00
Duke Pinball
Lighting - Backbox
$ 69.99
Lenticular Designs
11,000 (OBO)
Lubbock, TX
10,999
$ 19.95
SilverBall Designs
Filament Printing
