(Topic ID: 147107)
Metal to Metal Lubrication Question
By heatwave
  • 10 posts
  • 7 Pinsiders participating
  • Latest reply 3 years ago by heatwave
    #1 3 years ago
    Just picked up a 1967 Bally World Cup Soccer. Pretty complete and it works but the kicking mechanism (push down on the joystick to make the player kick) is somewhat sluggish for a few of the players.
    Question is what type of lubricant would you suggest for this metal to metal mechanism (shown below)? I'm wondering if people would recommend some of the teflon superlube? Light Machine oil? White lithium grease?
    It looks like there was some sort of lubrication used at some point. Machine has not been played in probably 10-15 years.
    FYI - the black specs in the picture are not carbon dust but rubber from the belt that spins the shaft that ultimately drives the players forward and backward. Very ingenious mechanism.
    Thanks-
    #2 3 years ago
    see my reply to your first post...
    #3 3 years ago
    I would go with the Teflon Superlube.
    White grease is thicker, slows down mechanical devices that dont have much "horsepower" behind them. Also it dries up and turns harder over time.
    #4 3 years ago
    Right or wrong I use finishline dry lube for bicycles. I use it on bicycles all the time and started using it on pins when I got into them.
    It is teflon based, doesn't attract dirt, and doesn't gum up.
    http://www.finishlineusa.com/products/chain-lubricants/dry-lube
    -1
    #5 3 years ago
    Quoted from Ven:
    That sounds like some cool s#!t. I would use that here. with the belt jis, its better to be dry.
    I need some of that.
    #6 3 years ago
    Quoted from Dr_of_Style:
    It goes on wet but quickly dries, and leaves a white dry film on the surface.
    #7 3 years ago
    Also if you use the finish line you have to make sure you clean off all the old caked on gunk before you apply it for the first time.
    #8 3 years ago
    I use Finish Line on rollers and shafts that are nylon on metal where the metal was once Teflon coated and the Teflon is now worn off. Light oil can work but attracts dust too easily which builds up and causes drag. Lube, even the Super Lube, is too sticky for my particular application.
    To answer the original poster, if the metal on metal is a pivot point or sleeve bearing, I would use light oil since the super lube may be too thick to allow quick return action. If its a rubbing point metal on metal, I would use the super lube.
    #9 3 years ago
    I use Tri-Flow Teflon lube with great results on metal to metal pivot points.
    Be sure to get the squeeze bottle. You'll be most likely to find it at a bike shop.
    #10 3 years ago
    I ended up using the suber-lube oil on the pivot piece (original photo) and some of the suber-lube gel on a sliding track for the goalies.
    I still need to investigate a few sluggish players that might be gummed up slightly at the pivot point under the player itself (waiting for the game manual to see if it is shows a better look).
    With the lubrication I have used the game does work much better than before and is a blast to play. It is even more fun with 2-player teams on each side. Plays a lot like the Super Chexx hockey games but the forward and back motion is motorized, controlled by a joystick.
    Thanks to all for the input
    $ 22.50
    $ 89.00
    Cabinet Parts
    Pappy's Pinball Palace
    $ 5,599.00
    Little Shop Of Games
    $ 239.99
    PinballBulbs
    Bright Lights Pinball
    £ 20.00
    Sillyoldelf Mods
    $ 89.99
    $ 5.00
    Doc's Pinball Shop
    £ 75.00
    PinballToys
    Flip N Out Pinball
    $ 6,999.00
    Classic Game Rooms
    $ 9.99
    Cabinet Parts
    SECRET SANTA SALE Out of stock
    Flashinstinct
    $ 9.99
    $ 46.99
    Lee's Parts
    $ 80.00
    Latenight Weeknight Mods
    Lighting - Backbox
    $ 99.99
    Yorktown Parts and Equip
