(Topic ID: 264231)
MET translucent drop targets not working
By Jimmyhonda
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by tilted81
#1 4 years ago
So, I installed translucent drop targets to replace the MET grave drop targets. I’m going to use an LED strip to light them up and make them glow. However, the drop targets are not working now? I wrapped electrical tape around the tab where the opto is, so the opto would work correctly. I tried the same technique with my deadpool translucent drop targets I installed and it worked great. However, the MET translucent drop targets don’t pop up at the start of a game or if you knock them down. Any idea what the issue could be? I was very careful with putting the drop target mech back together exactly how it’s supposed to and double checked that all the connectors are plugged in. Thanks for any help you can give me.
#2 4 years ago
Will it reset in the test function? If not, may just be an issue with the coil. The game should reset the bank at the start of a game or a ball if it recognizes even 1 target being down so unless all 3 or your switches are messed up I'd start looking at the coil. Also, just double check that they are registering in switch test mode as well.
#3 4 years ago
I saw mention in another thread that the optos for the drops in this case need a reflective surface to detect, so you need bright white instead of the black tape.
#4 4 years ago
Quoted from Betelgeuse:
Yep! Black absorbs the wavelengths of the red light and turns it into heat. White reflects it.
#5 4 years ago
10,650
Ontario, CA
Filament Printing
$ 29.95
$ 68.50
$ 55.00
The Flipper Room
$ 4.95
Mitchell Lighting
6,999
Downers Grove, IL
$ 7.00
Pinball Z
Lighting - Backbox
$ 12.95
$ 69.99
$ 9.99
Bent Mods
$ 29.99
Cento Creations
SilverBall Designs
$ 69.99
$ 14.00
SilverBall Designs
$ 93.00
10,600
$ 69.99
$ 24.00
Pin Monk
$ 700.00
Hardware
Chrome Candy
$ 19.95
SilverBall Designs
$ 25.50
$ 69.99
$ 19.95
SilverBall Designs
Chrome Candy
7,000 (OBO)
Elgin, OK
YouBentMyWookie
This page was printed from https://pinside.com/pinball/forum/topic/met-translucent-drop-targets-not-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
