(Topic ID: 218140)
MET Premium Feature Lamps Out - How to Fix?
By Golferron54
5 years ago
  • 4 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by j_m_
#1 5 years ago
I have a MET premium where the control (feature) lamps are out - this includes for example fuel, gauge and lights in front of Sparky. I checked all the fuses. Traced the wires from board to board for the feature lights to ensure they were all were seated tightly. I also ran diagnostics for the lamps, and they did not light up with exception of what you see in the photo lighting up (including the top 6 or so LEDs on the panel above Sparky). Otherwise, the game plays fine.
What do you suggest to get feature lamps working?
ron
#2 5 years ago
Quoted from Golferron54:
ron
check those fuses again,pull them out and test with a meter...if they are not working in test,attract mode,gameplay then its highly suspect that its a fuse.
#3 5 years ago
ron
GI lighting can go out completely with one connector under the PF that oxidizes. I don't think it controls the feature lights there, but it's likely a fuse or oxidized connection.
I don't think it will affect the feature lights, but you can try the suggestions in this thread when I had a GI problem with Met Prem:
https://pinside.com/pinball/forum/topic/all-gi-out-on-metallica-led-solution
#4 5 years ago
check the connection on both ends of the gray cat-5 cable that runs from the backbox to the underside of the playfield. I used to have a lot of issues with this happening intermittently, but it has since stopped
I believe that if there isn't enough slack in the cable, it can pull the cable from the connectors and cause sporadic issues like the ones that you are experiencing
$ 14.00
SilverBall Designs
10,600
$ 9.99
Bent Mods
$ 700.00
Hardware
Chrome Candy
$ 22.50
$ 200.00
Professor Pinball
$ 29.95
SilverBall Designs
11,000 (OBO)
Mount Pleasant, WI
$ 55.00
The Flipper Room
$ 160.00
Sparky Pinball
11,600 (OBO)
Lubbock, TX
$ 9.95
Mitchell Lighting
$ 1.00
Mitchell Lighting
$ 7.00
Pinball Z
10,999
Filament Printing
SilverBall Designs
$ 19.95
SilverBall Designs
$ 64.00
Lighting - Under Cabinet
$ 19.95
SilverBall Designs
$ 69.99
$ 29.95
$ 69.99
$ 69.99
This page was printed from https://pinside.com/pinball/forum/topic/met-premium-feature-lamps-out-how-to-fix and we tried optimising it for printing. Some page elements may have been deliberately hidden.
