SPOILER ALERT- skip over this if you don't want to know about END OF THE LINE
The WIZARD MODE is now in, END OF THE LINE. It now has a bank of four songs collected at the scoop for ''crank it up'' which is much like Ac/Dc, in that you build your song jackpot by hitting certain flashing shots on the playfield. Each one is very different, with the objective the same. There are some nice animations and sounds during these modes. To cash it out, you will see flashing shots you have to hit behind each of the 4 multiball shots (cross, snake, coffin and sparky) to re-light the scoop to either cash out or continue the same song. You have to play the multiballs to light crank it up to begin with. To light it once, I believe it's two or three different multiballs? I'm not 100%sure, but I know it gets harder as you do it again and again.
You can not pick the same song twice, it takes it away on your next trip to scoop when crank it up is lit. You can not change songs. Like AC/DC you lose your jackpot progession when you lose your ball, should you fail to cash it out.
So to do all four songs in crank it up to get to end of the line, takes some work. The good thing is you just have to get to each song, and not complete them or anything for progression to EOTL. That scoop is a bitch to hit, i'll tell ya. I did cash out a 44 million jackpot during Sandman, it was awesome.
On your final trip to CRANK IT UP, End of the Line will be your only choice. From there, it is some crazy animations of a car driving out of control and over a cliff, multiball, and BIG points. There does not appear to be a completion to this final mode, but the progression in this mode pays points of up to 10 and 20 million per shot, and pretty much everything is lit. Obviously, it plays the song too.
