(Topic ID: 242509)
Megatouch Force 2006 won't start up
By Ridgeman58
    #1 4 years ago
    Hi All,
    I have a Megatouch Force 2006 that has an intermittent problem. Occasionally when I turn on the machine i get a 1 long, 2 short beeps then constant beeps with nothing on the display. Sometimes when I reseat the SIM card it works. Other times when I unplug and replug the video connectors it works.
    I can't find beep codes specific to the game.
    Can anyone out there point me in the right direction.
    Thanks in advance,
    Scott
    #2 4 years ago
    Search Mike Keryeski. I think I found him on eBay. He was a wealth of information and help when my 2006 went down.
    If you haven't already, test the battery. If it's bad, this could be your problem There are procedures you can Google online on how to jump start the game once the battery is dead.
    #3 4 years ago
    Have you checked to see if your mother board is fully seated. They can be tricky as I had a similar problem and it turned out my MB was not properly seated.
    #4 4 years ago
    I think I recently replaced the battery. I'll check it though.
    Thanks for the input!
    Scott
    #5 4 years ago
    Quoted from RWH:
    I did not know it had to be "seated". Is that in a connector? I'll check that out as well.
    #6 4 years ago
    The mother board is a plug-in card with edge connections similar to pins. Do not take it out or put it in with the power on.
    1 month later
    #7 4 years ago
    check for bulging caps on the mother board too. if you see them, they need to be replaced.
    #8 4 years ago
    Caps look good
    #9 4 years ago
    RWH - My MB does not have edge connectors. Instead it has headers for ribbon cable. I re-seated them once and it worked, but the last time I tried it, it didn't work. The ribbon cable runs under the MB. I think I will buzz out the cable to make sure there are no broken conductors.
    This page was printed from https://pinside.com/pinball/forum/topic/megatouch-force-2006-won-t-start-up and we tried optimising it for printing. Some page elements may have been deliberately hidden.
