(Topic ID: 138872)
Medusa trouble shooting
By Madmax541
8 years ago
#1 8 years ago
Have a Medusa that I have been working on and is 95% Working.
When a game is started the 7 bank drop targets get reset and drops all but 2.
From what I have seen it should be starting with 1 then reset to 2, then reset to 3 continuing on to 7 targets are up.
The display gives credit for single drop target, so it sees it engaged but contacts on single target are open when drop target is up.
That single drop target (middle one) work in other configurations like 3, 5, 7targets
What am I missing
Looking for other ideas
#2 8 years ago
do you have a video of start-up? It could be a bad diode in the matrix. Mine did somthing similar, it was a diode.
#3 8 years ago
What does the switch test and solenoid tests say?
#4 8 years ago
Unfortunately if you search Pinside and RGP, you will see that a few of us have has the "exact same" issue and never found a fix. It's really a head scratcher because everything tests perfect...
https://pinside.com/pinball/forum/topic/bally-medusa-help-needed
Good luck and be sure to post a fix if you find one!
Rob Bell
Robsgameroom.com
#5 8 years ago
Does it drop alone or simultaneously with another target?
#6 8 years ago
Yes, same exact issue here. I can not seem to figure it out. I have replaced the board (original, to Alltek), switched the solenoid and even the lamp board and the transformer just to make sure. It must be a playfield issue.
#7 8 years ago
Someone please post a video.
#8 8 years ago
The coil under the apron needs 2 diodes. And there's only one diode...
Same problem on Medusa serials 1022 & 2092, solved by adding a diode or changing the coil. It seems to be a mess up between coils at Bally, when they've made the pinball. I would be interested to see what are the serials of your Medusa.
#9 8 years ago
Quoted from Manu2:
This is very interesting to read. All of the research I have done and I have never heard of this fix. I will try this as soon as I can on my buddy's game. Hopefully this is what we are looking for!
Thanks for posting this!
#10 8 years ago
I believe that is what I did to fix mine. I do remember for sure it was a diode problem. Just can't remember what coil. Look to see what solenoid if firing at the same time the target drops.
#11 8 years ago
You guys nailed it.
Kickout coil only had one diode.
Changed it problem solved.
Why does this bally need two diodes on some of the coils?
Another problem.
Game works fine except for one thing left flipper works for 2 to 4 flips and then stops working and starts working for 2 -4 then stops.
Flippers have been totally rebuilt, cabinet flipper switches are new.
Switches are gapped properly
Any thoughts?
#12 8 years ago
Quoted from Madmax541:
You guys nailed it.
Because of the solenoid expander ckt, voltage will back feed and energize multiple coils without the diode in place and working. (As you see with your drop target) Here is a video of proper target operation.
#13 8 years ago
This is really great news! My buddy checked his as well and only one diod. We will fix that ASAP!
#14 8 years ago
Could grounding of SDB cause intermittent flipper?
Only left flipper has issue.
#15 8 years ago
What's the issue with the flipper?
#16 8 years ago
#17 8 years ago
When it stops working, hold flipper button in and try wiggling connectors on SDB. Are the EOS switches new too?
#18 8 years ago
EOS are new
Hold flipper button wiggle wires no change.
How do you test solinode expander board?
#19 8 years ago
Also check solenoid expander and resoldered connector pins.
Switched out a SDB
All voltages correct @ flipper coil.
#20 8 years ago
Might be a bad flipper coil. A flipper has two coils. One is the power coil and the other is the hold coil. Hold down flipper button and manually lift the flipper. Partway up, it should lock the flipper in the up position. If it does this, replace the coil or make sure your EOS switch is closing properly. Just because a coil is new doesnt mean its good!
Protection
$ 149.95
Allteksystems
$ 17.00
$ 119.95
Allteksystems
$ 52.99
Pinball Shark
Shooter rods
$ 9.00
Cabinet Parts
Third Coast Pinball
Cabinet parts
Bob's Pinball Stuff
Other
$ 22.50
Magazines/books
Pinball Magazine
Magazines/books
$ 45.00
Playfield - Plastics
Plastics
3,900
Fairport, NY
$ 18.95
Led
$ 5.95
The Pinball Scientist
Protection
$ 69.99
Pinball Shark
Shooter rods
$ 12.00
$ 8.00
Third Coast Pinball
Displays
PinballSolutions.eu
Displays
$ 90.00
Displays
PinballSolutions.eu
Displays
$ 55.00
Displays
PinballSolutions.eu
Displays
$ 45.00
$ 139.00
Pinball Pimp
Other
$ 199.95
Third Coast Pinball
$ 22.95
Displays
PinballSolutions.eu
Displays
This page was printed from https://pinside.com/pinball/forum/topic/medusa-trouble-shooting and we tried optimising it for printing. Some page elements may have been deliberately hidden.
