My medusa back drops started acting flaky. I removed them - a couple bad solder joints and contacts out of alignment. I have to tweak those back targets every so often.
Here is my question and I never noticed it before. When the two green targets behind the drops are hit, the lights on the whole playfield do a little flash or at least dim for a millisecond. The center red target doesn't cause the lights to dim/flicker. It may have been there all along since I did the pf swap a couple of years back but just started noticing it after tweaking the back drops this time. I am using LEDs throughout the pf and bg.
Is this normal or do I likely have a wiring issue somewhere? I checked on line for videos of game play but could not find one that replicated what I am seeing.
thanks,
