(Topic ID: 193515)
Medusa project
By StratDoc
2 years ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by Venom_249
#1 2 years ago
I finally have found time to start working on a Medusa project.
The first thing I did was unplug all connections and check the voltage board and it checked out fine. I then plugged in the solenoid driver board and the high voltage fuse blew. I did a complete rebuild of the high voltage section and connected the voltage board to the solenoid board and the high voltage fuse did not blow and the voltages on the board were correct and stable.
I reconnected all the boards and the displays and powered on the game. The varistor in the cabinet blew. I can get another 130vac varistor but am concerned as to why it would blow with all the boards connected. No fuses on the voltage or solenoid boards blew. Just the varistor.
#2 2 years ago
varistor should only blow from high current entering the game. Varistor might have been weak. Replace it and see what happens.
#3 2 years ago
I will get one and post back. Also did not realize it at the time but it also caused my fuse box breaker to trip.
#4 2 years ago
Replaced the varistor and everything on the power side is fine. Game boots, no blown fuses, and goes into attract mode.
The displays are acting strange. It is not so much a flicker as it is garbled numbers running across the displays. I reflowed the solder joints on a couple of the displays but no change.
Also, I cannot get any solenoids to fire even when touching a ground wire to the transistor.
#5 2 years ago
Did you check the fuse on the playfield? Power at the coils?
#6 2 years ago
Thanks. I should have known.
Replaced the blown fuse and powered it and fuse blew again. Short somewhere.
#7 2 years ago
No prob, good luck finding your short medusa has a lot going on under there
$ 149.00
Third Coast Pinball
€ 3.95
Multigame
Displays
PinballSolutions.eu
Charleston, SC
