(Topic ID: 131381)
Medusa flipper help
By Tkaye
8 years ago
#1 8 years ago
I've got a Medusa that has a flipper issue. Just on the left side. Started with the upper zipper intermittent then not flipping then the lower left stopped as well.
After a little investigation my tech savvy friend and I have determined there's power at all 4 lugs. Also the left flipper switch wire has continuity to the board.
We did find this broken wire. Does someone have a pic of their Medusa that shows where this goes correctly?
Also when the game starts, is the relay on that little board supposed to go on and off or stay on?
Thanks everyone as always![attachment=2531903,undefined caption="image.jpg"][attachment=2531903,undefined caption="image.jpg"]
#2 8 years ago
I have a similar issue, your pics didn't post for some reason. I can check out that wire to see if I have an answer. Re-seat the connectors on the solenoid driver board and check resistance through the lines to and from the flippers on that board, like a blue, green, red and orange wires. If your getting more then say 1 Ohm that could be a cause for intermitant flippers (Should be 0.1 to 0.4). It's frustrating, what I did and am doing... New flipper switches, new enable relay from Digikey, brand new driver board pins, capacitors, did the sound board while I was at it. Flipper coils, EOS switches. I'm still working on replacing the molex female ends of the connectors.
If I still have a flipper problem after all that... time for a BIG fire!
#3 8 years ago
Oh the flipper enable relay is supposed to trip on/off at start up.
#4 8 years ago
Trying to upload again.
We did try reseating and checking the connectors were pined proper.
Also tested with new power board and MPU and same result. It's not a board problem. I have to look at switches or wires right?
#5 8 years ago
Agreed, That's the left zipper flipper switch assembly looking at it board up? That wire looks like it's coming from the coil lug, the common side. That's an odd break but I'll take a pic of mine but I'd guess there should be another loose end to that or that coil will not work.
#6 8 years ago
Thanks Nighthawk128. I'd appreciate the picture for sure.
#7 8 years ago
Just a heads up. Wires are color coded for a reason.
From your pic, and the extra blob of solider on the switch and the same color wire. It should go there.
While you are solidering. Also remove the solenoid expander board and reflow all the solider on it. Its just a good thing to do to make the game reliable.
#8 8 years ago
Thanks erak. I'll do that too. Still puzzling why I get no flip at all though on the left...
#9 8 years ago
Ok, took four pics.
Looks like our stuff is different but either way works, thing is my machine works. Study them and decide from there.
IMG_20150625_122134.jpgIMG_20150625_122134.jpgIMG_20150625_122144.jpgIMG_20150625_122144.jpgIMG_20150625_122204.jpgIMG_20150625_122204.jpgIMG_20150625_122118.jpgIMG_20150625_122118.jpg
#10 8 years ago
Your normally closed EOS switch could use replacing, it look worn right out from the pic.
#11 8 years ago
Thanks again Nighthawk128
8 months later
#12 8 years ago
Ok, New flipper issue...no flip on right side. Coils all have power and test fine. Transistors at the board all good. Fuses all good. I've been tracing wires until my eyes are blurry and still can't see a break or problem anywhere...Anyone have any other suggestions?
#13 8 years ago
Did you replace your NC EOS switches? That one was shot on the left side back then.
I did have a strange issue similar, ultimately a possible coincidence but replacing all the molex connector wire ends leading into the power board with new stuff (had to slightly ream out the connector holes) seemed to solve my right flipper not working condition when it magically appeared.
When stuff should work but doesn't I target resistance to flow through those old connectors. For the hell of it unplug those connectors, plug them back in, repeat 10 times each. See if your flipper comes back.
$ 18.95
7,000 (Firm)
Reno, NV
West Point, UT
$ 22.95
$ 69.00
Playfield - Plastics
Pinball Shark
$ 139.00
Pinball Pimp
£ 195.00
$ 119.95
Allteksystems
$ 69.00
Pinball Pimp
This page was printed from https://pinside.com/pinball/forum/topic/medusa-flipper-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
