(Topic ID: 316486)
Stranger Things - Lab Set - [[Medisinyl Mods]]
By Medisinyl
2 years ago
There are 1,122 posts in this topic. You are on page 23 of 23.
#1101 38 days ago
I keep saying I don’t need this, but now I think I do. Sigh. Please add me to the overflow list. Premium (new run) with UV kit. Thanks!
#1102 37 days ago
EDIT: Posts below suggest this may not be the case for most, but perhaps it will take getting more sets out to later builds to know for sure if this becomes common. [possibly a Pro only difference?]
It had been brought to my attention, that some new STh games could have a different connector for the tank assembly.
He notes his build is Nov. 2023.
It's the only time I've heard of this difference, so I presume not all new builds are this way (it's yet to be known if that manufacturing date will tell, so any feedback is appreciated).
If I'm informed of what this connector is, I could get some in case it's caught and I'm told ahead, though I expect most in pinball are able to swap the connector themselves and save the one I ship in case the set trades hands to someone with the more common type.
I question if the playfield hole is any different, as that other type looks like it would be hard to fit through what I recall.
537770915a45ff9b5a2f50b73dac4833ad53bd7e (resized).jpg537770915a45ff9b5a2f50b73dac4833ad53bd7e (resized).jpg6f5adae187dcd541e1892609072873a3f37cc68c (resized).jpg6f5adae187dcd541e1892609072873a3f37cc68c (resized).jpg
#1103 37 days ago
Quoted from Medisinyl:
[quoted image][quoted image]
Medisinyl
I just did an install on a 2023 run and almost got tripped up here. I disconnected that first and then realized that wasn’t the flasher (when I tried to pull it out). There are two wires coming through that same hole in the playfield. The other one, of course, matches the tank wiring harness connector.
I’ll snap a pic a little bit later.
#1104 37 days ago
Quoted from VinnyBlanc:
Medisinyl
Take a picture of the entire flasher you removed from the game.
#1105 37 days ago
Quoted from kciaccio:
Not sure what that other connector went to, but it was a nightmare to get back through the playfield as it was trapped under the left ramp.
#1106 37 days ago
Build date on mine is December 2023 and had no issues installing the tank assembly.
#1107 37 days ago
Not sure what that other connector went to, but it was a nightmare to get back through the playfield as it was trapped under the left ramp.[quoted image]
Did you have a pro or premium?
My flasher connection was different.
#1108 37 days ago
Premium.
#1109 37 days ago
Mine is a pro, I wonder if that is why my connector was different.
#1110 37 days ago
Did you actually pull the flasher out and confirm that is the right connector?
#1111 37 days ago
Yep.
#1112 36 days ago
Put me down for the premium I don't have yet, lol. If you're still doing the overflow. It'll have a UV kit for sure.
#1113 33 days ago
Has anyone experienced an issue where the sleep chamber. It is basically to tall ? The valve on top scratches the glass. I couldn’t remove the glass because the valve somehow blocked it, preventing it from sliding off. I have the new Stranger Things Premium version (latest build).
Mods looks outstanding and change totally perception of the playfiel ... but the sleep chamber could have been 5mm lower height to provide enough space between the glass and mod itself. Now my non-reflective glass is scratched.
#1114 32 days ago
Quoted from slomczas:
With this notice, I'll note it on the included paper to be wary (possible solution below).
This wasn't an issue of note on original builds (only one mention before the new run had one rubbing the glass), however, you're the 2nd to bring this up since the new run, so it is indeed to something to watch for and get more feedback on.
I am surprised it could scratch the glass, and am a sorry to hear about that.
This was designed with clearance on my LE (little bit of wiggle room for some game variation), and my design choices on the tank side, including proximity to the glass was mentioned earlier in the thread (specifically in response to the earlier Pinstadium question).
When I learn of build changes that affect fitment, I have adapted mods in the past. If it's mentioned again, my plan is to lose a little bit from the lid height and shave the wheel mount a little.
Possible solution for a tank that is too close (thus far very rare): The hand wheel on the top is a separate part from the lid. It should be able to be popped off (focusing on the center), then the nub on the lid could be sanded down, and wheel reattached (I use super glue gel for that piece).
Not a whole lot of height to be gained that way, but enough to prevent glass touching on one that is right into the limit, and one that would best maintain appearance vs repositioning, etc.
#1115 29 days ago
Put me on the overflow for a premium with UV kit please
#1116 22 days ago
Messages being sent to those with * in a moment (couple Pros out of order as a couple are partially complete).
A thread post noting model (Pro or Prem/LE) and if you have the Stern UV kit or not gets you on the overflow list.
Pricing is $850 + shipping for the overflow list (main list closed 12/31--overflow list may be tackled slower than the main list once there, as to focus on other projects--will announce a discontinuation date before finishing the main list).
Updated Main List (locked into the earlier $750 price point):
385) Boomshockalocka (A) * $
386) Fiddler (A) *
388) damienwibaux (A) *
389) ExportZ (A) *
390) Newtothis (A)
392) RxGolfer (A)
393) Buckman (A)
394) jobowens (A)
395) Thor_Odinson (A)
396) Pinballpal (A)
397) GrBJimmy (A)
398) ScottyC (A)
399) tk375 (A)
400) Scot0308 (A)
402) MGM2 (A)
403) zandman (A)
406) Jason_Jehosaphat (A)
407) MackPinzie (A)
408) hauntedpinballer (A)
409) Conrad (A)
410) VinnyBlanc (A)
411) dany1971 (A)
412) SankaraStones (A)
413) cooked71 (A)
414) PinBall-Newbie (A)
415) AceJedi (A)
416) holdemfiend (A)
417) pyrowolf (A)
419) Time4akshun (A)
420) Snickers45 (A)
421) Cem89 (A)
422) Lunchboxxx (A)
425) shlap (A)
426) icyjones (A)
427) Silvabullet (A)
428) menzelino (A)
429) Jedimarvel44 (A)
431) PDX-Mike (A)
432) JesseJames23 (A)
433) Medic (A)
435) RetroRalph (A)
436) Norcalpin (B) *
437) CloudHearts (A)
439) Jbeck1971 (A)
440) Mmoomey (B) *
441) qbass187 (A)
442) alleycat-pinball (A)
443) Turtlepower169 (A)
445) stuckey_t (A)
446) frogger (A)
447) Rlisenko (A)
448) fxdwg (A)
449) Swoods5688 (A)
450) njvc (A)
451) Pinzzz (A)
452) Deegs (A)
453) WileECoyote (A)
454) dukejules (B)
455) pinballspacebr (B)
456) KevHabs2021 (A)
457) LaButcher (A)
458) DonBrendano (B)
459) Rickbaron36 (A)
460) TooMetal (A)
461) lifefloat (A)
462) Razzz (A)
463) Gameroom-Goodies (A)
464) etc2010 (A)
465) Pinhacks (A)
466) Jaytech10 (A)
467) Vernisious (B)
468) Englishbaz09 (A)
469) Deadpool66 (B)
470) Tarheel4985 (A)
471) staceyflip (A)
472) petersonjandrew (A)
473) Alex-France (A)
474) Lazlo (A)
475) PDX-Mike (A)
476) Gman3 (A)
477) OkieNGa (A)
478) frankmac (A)
479) tomawax360 (A)
482) Totanwish (A)
483) beltking (A)
484) Paseb (A)
485) copperpot (A)
486) QKills (A)
487) ccbiggsoo7 (A)
488) jorge5240 (A)
489) TahoeTony (A)
490) Jmxdc (A)
491) schwts (A)
492) YERFDOG (A)
493) danastude (A)
493) Apk1978 (A)
494) fattrain (A)
495) mbrave77 (A)
496) Alwayslooking (B)
497) badbilly27 (A)
498) SacPinDaddy
499) Freakyguy666 (A)
500) OreoFlapjacks (A)
501) pit3239 (A)
502) Wmattson (???)
503) Nicoli125 (A)
504) sretooh (A)
505) krispyk577 (A-0)
506) Miami13 (A)
507) Scrappy01 (A)
508) BeeGeeMtl (A)
509) Shady32 (A)
510) gameroomfan (A)
511) fraustl (A)
512) ALSteve (A)
513) CaptainNavidad (A)
514) Nstone4425 (A)
515) TaTa (A)
516) Aniraf (A)
518) RunPaPa (A) *
519) Hvymlt (A)
520) Hellcat (A)
521) madscientist101 (A)
522) brooklynknight (A-0)
523) Rygolfer (A)
524) vintage4life (B)
525) Ollulanus (A)
526) SuperMas77 (A)
527) Sgoode (B)
528) gixxerjoe (A)
529) Shemp-Stooge (A)
Overflow List ($850 + shipping):
1) Davi (A)
2) waynetrane (A)
3) 1958Pinhead (A)
4) Bobbdobalina (B)
6) Spaghetti73 (A)
7) stompeN (A)
8) C-Note (A)
9) Bmarion0913 (B)
10) Mando (A)
11) graffixpinball (A)
12) judgejohn (A)
13) cleanandlevel (2x A)
14) Jimmyzz (A)
15) ireweav (A)
16) Tastysirloin (A)
17) drbrain (A)
18/19/20) Flipper-airbrush (3x A)
21) Requis (A)
22) pinner11 (B)
23) Minnpin65
24) Boomshockalocka (A)
25) itsover9000 (B)
26) Roofer67 (B)
27) mjude76 (A)
28) Chainsaw (A)
29) arcadequarters (A)
30) GorillaBiscuits (A)
31) DavidGQ (A)
32) gharadon (A)
33) Tintin (A)
34) Hibou (A)
35) PinB (A)
36) Princev911 (B-0)
37) Tiebreakers (A)
38) Thundar2000 (A)
39) DavidD (A)
40) Kevster219 (B)
41) hcj13 (A)
42) davedecrom (A)
43) Maverick222 (A)
44) AndHart120 (A)
45) DieselDave (A)
46) Neilio (A)
47) ILLINI_PINBALL (A)
48) xsonics2k2 (A)
49) nicholasdeorio (B)
50) Imo (A)
51) Mylstar (A)
52) TonyScoots (A)
53) JorgesArcade (A)
54) ToolfanJEff (A)
55) Rene86 (A)
56) Thunder22 (A)
57) Souderhead (A)
58) evileye (A)
59) SgtPin18 (A)
60) J_Striker (A)
Added 20 days ago:
48 - X
Fiddler - $
#1117 22 days ago
Quoted from brooklynknight:
Please add me to overflow list. Newest build premium with Pinstadiums (Atom Fusions the smallest ones)
Quoted from fraustl:
At me to the overflow list. Premium with UV. Thanks!
You both had spots already on the main list, so I left those as is instead.
#1118 20 days ago
Put me on the overflow list. I have premium with uv kit.
#1119 18 days ago
Please add me with premium and UV kit.
Thanks,
John
#1120 5 days ago
Please add me to the overflow list Premium.
#1121 4 days ago
Can you please add me to the overflow list. I have a 2023 Pro with UV kit. Thank you!
#1122 34 hours ago
Can you please put me on the overflow list. 2023 Premium with UV kit. Thanks!
$ 8.95
Pin Monk
8,970 (OBO)
Linn Creek, MO
$ 48.00
Slipstream Mod Shop
$ 189.00
Slipstream Mod Shop
$ 6,995.00
Pinball Alley
$ 27.95
$ 38.00
Slipstream Mod Shop
$ 24.00
Pinhead mods
$ 50.00
Duke Pinball
7,200
Bakersfield, CA
Filament Printing
$ 24.00
Pinhead mods
$ 130.00
9,300
Staten Island, NY
arcade-cabinets.com
Pin Monk
Trade
Machine - For Trade
Bluffton, IN
€ 99.00
Lighting - Under Cabinet
Watssapen shop
$ 38.00
Slipstream Mod Shop
PinShades
$ 18.00
Volcano Pinball
