Edit this
Medieval's Mad Trolls In Basement
Wednesday June 12th 2019
Dear Lloyd.
We’ve got a Medieval Madness remake here in the office and have a problem we can’t work out how to fix!
One of the trolls will pop up and then immediately disappear into the table. We were getting the troll up switch error but the switch is definitely working. The troll test mode behaves the same – troll pops up and immediately disappears. Any ideas?
I used to be a Newt
Dear Newt
This sounds like the troll face leaf blade switch is too sensitive and registers a hit going up and drops. You'd need to adjust it so it's less sensitive. Long shot would be a broken wire
on the coil. Power works but hold winding isn't. Check big wires to the coil, and dig around the thin wires from the coil to the coil lugs.
Thank you,
