Can anyone give me advice on how to fix the ‘Left gate stuck closed’ test report on Medieval Madness? Everything seems to be working just fine, just can’t clear that message. Thanks...
Does the gate work? when you launch the ball for super skill shot [holding left flipper] does the ball zoom all the way around to the flippers? The "left gate" should open and let the ball under it.
The Williams programming usually would pop up an error if a switch isn't hit in ten games or 30 balls, you can’t clear it but if the switch triggers then it’ll go away
Quoted from TRUMETLAR:
Page 154 in the manual. Did you try that ?
It's an error that comes up frequently even when everything is working. Go into test mode and test orbits both directions 10 or 15 times, then test with each gate closed 10 or 15 times each, then play a game. The error should go away. It's aggravating to get rid of.
