I just got a nice MM and have fixed a number of the "simple items" on the game, but have 2 items I can't get right. I have a few games, but not the best at fixing (but learning)...
1. Left ball return/left joust/ball eject 7 of 10 times launched it straight down the center drain. Is there a way to adjust this? Is it a leveling issue? Other? I dont mind a challenge, but quite lame when you get drained w zero chance to do anything (after you do something successfully, like say hit in and destroy a castle). Any ideas?
2. The right lane rollover in the top right is intermittent, a lot of times not working. Im thinking maybe the rollover needs to be bent down a bit? When Im in test mode and push the switch it works, but when ball goes over during game mode it doesnt work. Its very tight in there, even if bending it a bit is answer (is it?) how do I best get in there to do it?
3....ok guess there is a 3rd. The left troll is very hard to trigger, you have to whack it very hard and directly in the front of it to trigger a hit, where the other you can hit if softer and from the sides. The left one feels a bit looser when I shake it around. Any ideas here to make it more responsive?
Many thanks guys!
