Hi. My Revenge from Mars Skip Ramp suddenly sticks in the UP position.
The ramp should fall back down when the coil is not energized.
Only gravity seems to control the down position. There is no spring, and i confirmed this with the manual on page 2-17.
I replaced the coil sleeve, cleaned the bell armature, and all other parts with no luck.
I took it apart again, and gave the bell armature a light wet sand to remove any possible burrs. Still no luck.
I lightly oiled the metal to metal points, even though they all appear clear from binding. Still bo luck.
I thought maybe the bell armature and coil stop could be magnatized. I took them out again, and checked if a screw would be attracted to either, but no.
The ramp only stays up after being lifted using the coil power. When i raise it manually, it does not stay in the up position, even when i slam it up as hard as i possibly can.
To rule out any power still going to the coil, i turned the power off, and the skip ramp stays raised, until i give it a little tap, or some other vibration from a fliiper, etc.
What am i missing here? Is there another way to check for magnatism?
This is a home use only machine, with very low plays. It has never been abused. Thanks. Sparky
