1968 Gottlieb Spin Wheel - 120v coil reset bank under playfield which controls the field sequences will not consistently allow all relays to engage to reset known state.
Example Video -
Shows the reset manually - 5 lights on, when normal reset via 120V coil, not all relays reset, several lights don't come back on as a good indicator it didn't reset.
Troubleshooting I have worked through:
- cleaned all metal on metal friction points where relays slide as reset bar gets pulled back (see picture)
- to rule it out, I did lube one of the coil reset items, did not make a difference
- cleaned 120V coil plastic tube and metal shaft (reassembled dry)
- filed and adjusted armature switch that breaks the 120V coil when relay #6 is reset
- adjusted position of the 120v coil, down all the way, up all the way, and multiple positions in the middle
- adjusted thumb screws to be even with the edges of the holder used to flip down whole reset bank - as noted on pinrepair.com, tried other positions as well
- sequence relay #1 (on the left) I shorted the return spring by 2 turns, no change
- verified on resetting, no switches are putting force on the bar - no switches to adjust
I considered all new springs, however when I shorted one, it didn't have an effect. When I pushed the reset bar by hand after a reset, it does not take much to click the relays that didn't reset.
I can't see anything in the way that would be interfering with the reset bar, hard place to work on under the playfield. There are a couple wires that come down the but they appear to be out of the way.
Seeking any tips on things I can try. The other reset bank got the same treatment regarding cleaning. It seems to be working without any issues.
BTW working around the 120V relay, so far I haven't done the 60hertz dance! Hope to get this figured out so I can stop working so close to that section!!
Cheers!
Referenced sources for troubleshooting:
- http://www.pinrepair.com/em/index3.htm
- https://user.xmission.com/~daina/tips/pub/tip0435.html
- a few pinside posts, but seemly they were not mechanical issues
