So the Drac Trac on my recently acquired MB has some wear. The black is worn off and the wood is worn down a bit in front of the ramp. Otherwise it's pretty good. After doing some research there is a bracket that attaches under the playfield to match up the playfield heights. Apparently this is common in early MB's so I ordered it from Marco for the fix. I also ordered the overlay to go over the Drac Trac.
My question is: what would you guys use to build up the little bit of pf wear so that the ball will go smoothly up the ramp and so I can also install the new overlay on top of it? Some say to use some sort of epoxy but a friend of mine tried some on his NGG without success. My brother suggested bondo. What do you guys use for things like this?
