Does anyone know what the current limits are for the electromagnets used for WPC magna-save; i.e. is the design of the magnet already maxed out at 50V, so that trying to double the magnetic force using higher current (via voltage) would not be possible without risking heat damage to the coil? I'd use a one-second activation time. Would doing so make any difference saving SDTM on WCS94?
Background: If part of the WCS94 game play is lighting magna-save, then it ought to be worth something. I've had the pin for many years and Magna-save is nothing but disappointment ... why bother with it, it never accomplishes anything? I'm thinking a person could use the magna-save solenoid driver to engage a separate higher voltage / current driver for the electromagnet. I'd add a thermal fuse just in case the controller stuck in the on position. Yeah, I've seen the pin with a black spot where the magna-save was.
Thanks.
