I'm having a very frustrating issue w/ Maverick. I have one of two options...I can either bang my head against the wall hoping that the vibrations from the wall will magically fix this once & for all. Or my next to last option would be to contact the excellent community at Pinside, w/ some knowledgeable insight to remedy this situation. Anyhow, I believe (99%) that I have an overheating issue somewhere within the machine. The problem seemed to manifest after playing a game & the first drop target underneath the Lauren Belle was wedged. This prevented the whole row from resetting back into place. Of coarse I replaced the broken drop target, then very strange things started happening within the machine. Initially when starting the machine, then playing a game or two ~ approximately after a half hour or so the machine gradually starts "acting up"...
1. The relay that controls the Lauren Belle starts clicking gradually, then gets progressively worse.
2. Then the underneath playfield lights blinks uncontrollably. As the relay clicks clicks.
3. After a minute or two the DMD flutters, then blanks out.
4. During a game when this problem arises, the Lauren Belle will "toot" gradually then becomes progressively worse. As the Lauren Belle "toots", the DMD will only show that image of the boat.
Here is what was done so far as to try to fix the issue...
1. The resistors in the MPU were replaced. The original resistors had a chalky residue.
2. The voltage regulator in the power supply board was replaced.
3. The rectifier in the power supply was replaced.
4. All the caps in the power supply were replaced.
5. The relay board that controls the Lauren Belle was replaced.
Any advice would be greatly appreciated!!!
