Quoted from ahdelarge:Getting closer!
So, I have to do the following:
Get the wiring sorted on the slingshot switches. Would like an actual photo of your Maverick machine if possible as some strange things have been done to this one, so I'd like a direct comparison (if at all possible).
Will then need to test the coil and diode for the 5 bank drop target bank (upper left).
Finally, the left flipper works, but the switch isn't registering in switch test. SSFB transistor could be the cause or would this be a switch matrix issue again?
In switch test, momentarily short the switch drive for the flippers at the SSFB CN1 pin 4 (GRN-GRY) to switch return CN1 pin 5 (WHT-VIO). If it registers the switch then the problem is on the SSFB (could be output transistors, cold soldering or bad wire crimp on the CN1 connector. If it does not register, then a break in the daisy chained switch wiring is suspect. The flipper switch matrix signal for left flipper #63 is between switch #55 right ramp skill shot and the CPU, and all the other switches in the row work so it would not be a problem at the CPU connector but could be a break at switch #55.
As far as the slings go, pics below. The left is a bit easier to see than the right.
