Quoted from Pinminister:Wayout440, is it possible you can tell me what that connector plugs into on the top of the playfield? I'm looking at mine again and I can not find a black/gray connector going to the top of the playfield. Also can you shed any light on my switch problem. I don't see any thing that these switches have in common.
Thanks again .....
The connector grey and black wires run to the opto transmitters for the Lauren Belle lock switches. Without the transmitter LEDs getting power, your lock switches 45 and 46 should be failing switch tests.
The switches you reported failing might appear scattered, and don't necessarily have to be caused by one problem, there could be multiple problems. I noticed one thing common, switches 18, 26, and 34 are in the same row. One wire could have broken off one switch causing all three to not register. Or a totally different switch in row 2 could have a broken wire that daisy chains over to these switches.
With scattered multiple switches out I find it is usually easiest to start at one end of a row or column and work my way through checking continuity from the backbox connector and then one switch to the next in the daisy chain. It's a pain, but usually I find a broken wire, diode or something eventually- and often the culprit is on a working switch that feeds off to the switches that have failed.
