Hi,
I'm trying to fix my Maverick. I can't figure out what's the problem...
When I boot the pinball, it says "Bottom Lock = Good Top Lock = Bad Wheel Entrance = Good"
First, I installed the reed switch (green / white wires 2 pin connector under the playfield) and it works great! It registers the ball everytime it goes into the paddle wheel with the DMD animation and boat sound. Before I installed the reed switch everytime I went into the boat, the ball search mode activated and then, released the ball. There were no boat sound or animation on the DMD.
Now, even if the ball search mode doesn't activate on the first ball lock, it releases the ball anyway after 3-4 seconds. I can clearly see that both sets of opto red lights are working. I also cleaned them gently with 70% alcohol and Q-Tips.
When I unplug both the 2 little connectors on the left side of the optos (on top of the playfield), when I boot the pin, I have this message on the DMD: "Bottom Lock = Good Top Lock = Good Wheel Entrance = Good" but nothing changes. I have the same issues even if everything detects "good" or "bad".
In other words, I can't lock balls into the boat.
Am I supposed to unplug other connectors? Does the reed switch replaces the optos? Where should I search? Any help will be appreciated.
Thank you!
