(Topic ID: 329523)
Maverick ball launch delay
By keystonePig
1 year ago
    #1 1 year ago
    I just picked up my first pin (#Maverick) and it plays great; however, there seems to be a delay in ball launch during Angels Revenge, Runaway Stagecoach and Bank Heist modes. The machine captures the ball during the skill shot, the counter starts counting down from 30 sec then after approximately 10 secs the machine goes through the "lost ball cycle" then kicks out the ball from the launch ramp. The game plays as normal but shorts you 10 seconds.
    Anyone have similar problems or is this normal?
    Thanks in advance
    #2 1 year ago
    I'd suspect where the ball is sitting, that switch is bad.
    The game is going into ball search because it isn't seeing the ball.
    I can't remember how this game plays, but the ball capture inside the Lauren Belle uses opto switches, and I've had to replace optos here on every Maverick I've worked on.
    Switch test is your friend! Test with a ball, not with your finger!
    #3 1 year ago
    As said switch test and will the ball only has too be a switch
    #4 1 year ago
    Excellent. Thank you both. I will test this tonight. It will likely be the switch on the launch rail under the skill shot plastic.
    #5 1 year ago
    Quoted from keystonePig:
    I am thinking the same thing my acts up sometimes there also
    #6 1 year ago
    Also check that you have the correct number of balls in the game.
    Should be 6 balls in this one according to the manual.
    Some games will play with a ball short so worth checking
    1 month later
    #7 1 year ago
    Quoted from homebrood:
    I checked and the game only had 5 balls (4 in trough and one captive)
    I added a ball to the trough and now when the game starts it loads a ball in the plunger, but then it must think that the ball drained and it launches a second ball on top of the first. Very strange
    #8 1 year ago
    But remember, you don't count the captive ball as one of the balls.
    Number 9 in the setup instructions in the manual states.
    9. Place the six pinballs on the playfield near the outhole, and carefully reinstall the playfield glass.
    You may need one more ball! Should be 6 balls plus the captive!
    #9 1 year ago
    This game only takes 5 balls total. 1 of which is the captive ball.
    #10 1 year ago
    Quoted from crujones4life:
    I thought 6 balls sounded like too many, but the manual .pdf in the IPBB says 6 balls.
    It's a typo in the manual though, as I see it only has a 4 ball trough.
    They probably copied that page from another manual, and forgot to change that line to 4 balls.
    There are lots of mistakes in those manuals I should have known better!
    Thanks for clearing that up crujones!
    #11 1 year ago
    Yes this is right 4 ball game with the captive ball
    This page was printed from https://pinside.com/pinball/forum/topic/maverick-ball-launch-delay and we tried optimising it for printing. Some page elements may have been deliberately hidden.
