My Maverick's flipper's do not work. I have 70volts coming out of pins # 11 and 12 at connector CN2 on the flipper board. I know it sounds a little high but I was told it is unused voltage and it will drop as soon as the flipper is used which sounds right. Could it be possible there is a problem with the cpu. The ground for the flipper is supposed to come from CN19 which I believe runs through the 6volt cube. I just don't know when the cube is supposed to be active. I would appreciate any help. Thanks Bill
