My Williams Flash control lamps do not light. At first I thought it was an issue with the connector to the boards but they seem to be solid. Furthermore, all the control lamps are out. I am assuming if it were a connector issue, some of the lamps would light and only the loose wires wouldn't. Does this make sense?
Upon further exploration I traced the wires under the playfield. In doing so I found one of the Molex connectors to be hot to the touch. I took it apart to check it out. I found something interesting but not sure if it is relevant:
The male side has 17 wires/connections, the female side has 18 wires going in. I couldn't find any loose or dangling wires to be connected. Could this be my problem? Does anyone have a picture of a similar working Flash Molex connector for me to compare to mine?
IMG_20141013_232128-754.jpg IMG_20141013_232325-789.jpg IMG_20141013_232522-321.jpg IMG_20141013_232735.jpg
