(Topic ID: 262451)
match lights
By wesley
37 days ago
  • 58 posts
  • 6 Pinsiders participating
  • Latest reply 26 days ago by DaMoib
    There have been 8 images uploaded to this topic. (View topic image gallery).
    There are 58 posts in this topic. You are on page 1 of 2.
    #1 37 days ago
    Hi everyone. Again in my 76 Gottlieb Volley, the match lights won't light up at end of game. I checked all the bulbs and they aren't burned out. Match system does work because I can here the knocker hit at end of game ( when it does match ). Any ideas sure can help...thanks
    #2 37 days ago
    contact on the game over relay... No diagram?
    #3 37 days ago
    Hi. Do you mean schematics?
    #4 37 days ago
    Quoted from wesley:
    yes... the most common reason is the contact on game over
    #5 37 days ago
    Where is the game over relay?
    #6 37 days ago
    Quoted from wesley:
    Looking at my Atlantis schematic, there is no game over relay, its actually position 6 on the ball count unit.
    So if Volley is similar see if your ball count unit in the head goes to position 6. if it does press on the spring loaded shoes and it may be just a dirty rivet there. Does your game over light come on? dia shows its tapped off of that. And there is the AS mini stepper relay in the head that moves between the 10 choices
    #7 36 days ago
    Is there any difference between a 3 or a 5 ball game?
    #8 36 days ago
    Good choice on both of you. I'll get back.
    #9 36 days ago
    Yes, the game over light comes on.
    #10 36 days ago
    Check out this switch on the "R" relay (Hold Relay).
    #11 36 days ago
    Great pic of the schematics.
    #12 36 days ago
    Got the match light to "light", but it always reads 00. Doesn't change.
    #13 36 days ago
    You've gotten a "00" match value after multiple games?
    During the game, the wipers on the FS Stepper should rotate when the center pop bumper is hit. This is what generates the "random" number for matching.
    Does your FS stepper move during a game?
    #14 36 days ago
    Quoted from DaMoib:
    yes these little mini stepper are a real pain. need to be cleaned up to work properly. You'll note that it is the only relay on its own jones plug so they can be demounted for cleaning
    #15 36 days ago
    Thanks. I will take look. I might get back to you pin guys in case I can't find the FS stepper. Were would it be?
    #16 36 days ago
    In the back box/head, on the left, right next to AX
    #17 30 days ago
    Thanks everyone. The match system works because when it matches I can hear the knocker hit meaning free game, but the matching lights just won't come on.
    #18 30 days ago
    Quoted from wesley:
    Is this still the case? Have you checked out the switch on the R relay and the operation/condition of the FS stepper?
    #19 30 days ago
    You can use a jumper wire to short the FS relay lightbulb disc (WH - white wire is common) to the head general illumination wiring BLK-RED. It will illuminate the match numbers (and the Game Over light) throughout the game and help you align the score with the match number (as well as testing all match bulbs). You advance the match number on Volley by hitting the center pop bumper during a game.
    Also some info on the AS-type relay (known as the "FS relay" in Volley) that controls your match function:
    http://www.pinrepair.com/em/index2.htm#steps
    search for "AS relay stepper"
    #20 30 days ago
    DeMoib, the FS stepper won't move when I hit the middle bumper. Seems to be gummed up. What's the best way to clean it?
    #21 30 days ago
    First, try the tips in the link I sent - the section beginning with "There are a couple of keys to servicing an AS stepper." If that doesn't work, we'll go from there...
    #22 30 days ago
    Thanks. Will let you know.
    #23 30 days ago
    I tightened the spring, but I mostly have to push into place the plastic arm that turns the plastic wheel or axle.
    #24 30 days ago
    What is the condition of the two non-moving contact plates (or discs as they are also called)? Did they need cleaning and re-lubing?
    #25 30 days ago
    I have the FS relay pulled out and the tension bars aren't applying too much pressure on the discs.
    #26 30 days ago
    Also when I force the plastic arm back in to its proper position there is a click from one of the relays in the cabinet.
    #27 30 days ago
    Quoted from wesley:
    Pressure from the tension bar is one thing, but the drag of two wipers trying to move across two dirty and/or gummy discs is another. I'd still recommend cleaning the discs and lubing them. Can you take a picture and post it?
    #28 30 days ago
    Sure. I'll take a picture and try to post it.
    #29 30 days ago
    Did you get it ?
    #30 30 days ago
    Also, here is that coil that won't fire and reset the bank.
    #31 30 days ago
    Quoted from wesley:
    The make/break switch mounted between the two discs is controlling the Alternating relay ("A" relay) when you manually toggle the FS relay. The A relay controls some of the rollover switch lights and their associated point scoring.
    That's another thing to check according to the pinrepair site... their recommendations, in order, were:
    1) Clean and lube the disc/wiper units
    2) Make sure the switch on top of the relay (the make/break in this case) is not pressing down on the cam too hard and causing the relay to bind.
    3) Tighten spring
    4) Replace parts
    As you progress down this list, you test the relay after each step, and stop once the relay is working. Not all steps are needed in all cases.
    #32 30 days ago
    Quoted from wesley:
    Did you get it ?[quoted image]
    Yep, got it... it's not the dirtiest that I've seen (the one on the pinrepair site looks lots worse), but that's not to say that they (both sides) couldn't stand a good cleaning and lube. Do you have the 600 grit sandpaper and some grease:
    https://pinside.com/pinball/forum/topic/best-grease
    #33 30 days ago
    Is the A relay suppose to move everytime the middle bumper is struck? Because the lever with the spring on is sometimes still touching the white coil, therefore not putting the plastic arm back in position.
    #34 30 days ago
    Got the sandpaper.
    #35 30 days ago
    Quoted from wesley:
    Also, here is that coil that won't fire and reset the bank.[quoted image]
    The good news is that the match relay can wait if you have to get some supplies - matching doesn't affect the gameplay. Bank reset however... I guess you never solved that issue? Did you check the fuse and the switches in this circuit (remember, ***unplug the machine*** when working in the bank reset area):
    https://pinside.com/pinball/forum/topic/1976-volley-1
    #36 30 days ago
    Never solved it. Trying to do too much. But you're correct, the match can wait. I checked the fuses, all are good. What was the switches again for that bank relay?
    #37 30 days ago
    Quoted from wesley:
    The A relay or the FS relay?
    The middle bumper and FS activate together and the make/break switch on FS along with a make/break on the drop targets control the A relay.
    Your FS relay needs to be freed up...
    #38 30 days ago
    Quoted from wesley:
    #39 30 days ago
    For the sequence bank reset,I can't find a1amp fuse anywhere.
    #40 30 days ago
    I found it, but it looks okay. It has a wire coming from each end of the fuse.
    #41 29 days ago
    Quoted from wesley:
    It doesn't look blown? The fuse holder is clean and shiny?
    Also check that the bank's reset arm, along with the solenoid plunger it is connected to, move freely:
    #42 29 days ago
    fuse is good, arm is attached to the plunger or coil. all moves freely. what else should I do?
    #43 29 days ago
    i'm at work so I have to be careful. don't want the boss to catch me.
    #44 29 days ago
    With the machine unplugged, check the three switches from the schematic:
    1) the switch on Relay S with a red and a yellow wire(s) on it (should be open)
    2) the switch on Relay Q with a blue and an orange wire(s) on it (should be closed)
    3) motor switch 4B with a yellow and an orange wire(s) on it (should be open)
    manually exercise the switches:
    and if I may borrow HowardR 's words:
    For a switch to work 3 things are necessary:
    1) When open, there should be a small space between the contact points (duh)
    2) When closing, the long blade's contact point should push the short blade's contact point enough to move the short blade
    3) The contact points should be clean, which they usually will be if #2 is happening
    Added 27 days ago:
    manually exercise the switches *by actuating the armature*
    #45 29 days ago
    THANKS. I WILL GIVE IT A TRY TONIGHT AND LET YOU KNOW. SORRY IF I HAD TOO MANY QUESTIONS LAST NIGHT
    #46 28 days ago
    I tinkered last night "with the pinball" and the problem is as you said with the Q relay. When I triggered it the bank reset coil wouldn't work. I tested the copper fingers and when I push a certain one it fired the reset target coils and the main bank coil.
    #47 28 days ago
    I'm reading your last post and getting a little nervous. Can you describe in some more detail how you are testing these switches. It sounds like you are manipulating switch blades with the power on? Keep in mind that these switches are at 120 volts. You should be checking and adjusting them with the pinball machine *UNPLUGGED*.
    #48 27 days ago
    Thanks, I've been shocked before. I had quite a few EM'S before. Problem is with the Q relay if I push on one of the points it will fire both the target banks and the main reset bank. But if I hit the game play button it won't trigger the main reset coil. Once again, thanks about my safety.
    #49 27 days ago
    Any ideas about the Q coil. Where the positions of the points should be? Thanks.
    #50 27 days ago
    Quoted from wesley:
    When you refer to the "game play button", you're referring to the red replay button on the coin door, correct? If so, when this button is pressed, does:
    1) The S relay pull in (activate)?
    2) The motor turn?
    3) The targets reset?
    4) But the bank reset does not?
    If so... do the procedure I've indicated in post #44 (and added the armature note here):
    Quoted from DaMoib:
    manually exercise the switches *by actuating the armature*:
    As far as being shocked before, I just have to say that previous shocks do not make you immune from future and potentially, more serious, shocks. Please check these switches out with the machine unplugged. When manually activating relays with the power on, use a wooden stick and wear gloves. That's the last I'll say on the matter, I promise
    $ 76.95
    Williamson Pinball Mods
    $ 69.99
    $ 13.50
    Playfield - Plastics
    $ 159.99
    $ 175.00
    Professor Pinball
    $ 300.00
    Gameroom Mods
    $ 7.00
    $ 7,395.00
    Great American Pinball
    $ 27.00
    $ 128.00
    $ 34.94
    Plastic 9 for Pin-Bot Out of stock
    Pinball-Mods.com
    $ 65.00
    Lighting - Backbox
    Arcade Upkeep
    $ 57.95
    PinBoss Mods
    $ 59.95
    Hookedonpinball.com
    $ 49.99
    $ 17.95
    $ 7,299.00
    Arizona Pinball
    $ 26.50
    The MOD Couple
