Hi everyone. I'm working on a SS Mata which was buried in a garage for 30 years. I've spent a few weeks replacing a few coils that tested bad, all fuses, and replaced the MPU with an Alltek. I also cleaned checked all connectors and reflowed some contacts. Ran through the safe powerup at http://www.pinwiki.com/wiki/index.php?title=Bally/Stern#Powering_up_the_first_time and she started up and played her tune. The MPU flashed appropriately, all voltages are good, and she'll coin up, but will not start a game. I also ran through the self tests and everything from the general illumination, to displays, and coils seem good.
This seems like a common issue with Matas from the threads I've read, and I've tried a few suggested fixes. Checked the start switch for grounding, checked the wires that run from the start switch through the roll tilt, adjusted the outhole switch, and a few other minor adjustments. Probably not relevant, but the upper right score display reads 11 after a few seconds of powering up. Thought it was just a bookkeeping reference. I'm sure it's something simple, just looking for a nudge in the right direction.
