Hello all, Recently I turned on my machine and it did not boot up. I checked the MPU (alltek) and none of the LED's were coming on at all. I tested the test points and did not have power at the 5volt test points's. I checked the schematic and decided to take a look at the solenoid driver board that delivers power to the MPU. I found that at the test points 1 and 3 on the solenoid driver board, I had no voltage (.07volts) and they should be 5 volts. Has anyone repaired a board with this issue? I am assuming that the voltage regulator on the solenoid driver board is needing replaced. TO BE NOTED: I did check the voltages and fuses on the power supply and they are fine. ALSO, all of the general illumination lights are coming on, but no power at the MPU. Looking for people to chime in on this issue.
