(Topic ID: 232799)
Mata Hari quit booting
By Nikrox2
1 year ago
  • 49 posts
  • 9 Pinsiders participating
  • Latest reply 1 year ago by mrm_4
There have been 9 images uploaded to this topic. (View topic image gallery).
#1 1 year ago
Been working on a MH and finally brought her home last night. Worked Till late and again this morning and had her nearly 100% working. Thought I’d hit a home run.
Then I took a lunch break and left her powered on.
When I came back half hour later the displays are out and game will not boot up
I’ve pulled and replaced all 8 fuses (6 on the Rectifier board. One on the SDB and one under the playfield.)
The small one on the SDB was empty and one end cap was loose. (it’s a 3/16A. And it’s a 1” long fuse. So I only have a 5A in that size. I’ve put that in just to try to get it working again)
When I power her up I get the 7 total flashes on the cpu board and the small relay cube in the SDB clicks. Then nothing No music no start / boot up.
It was playing All drop targets and saucer working All scoring Able to use the diagnostic switch and got just about all working. Now nuttin
Any suggestions or some tech advice on resolving this one?
#2 1 year ago
WOAH!!! first off get that 5A fuse out of that 3/16 holder! never over fuse a game or you might get a transformer fire...... secondly does the game coin up? maybe you just lost your display voltage. is this an original cpu board or an alltek board? also check under the playfield fuses if there are any...
#3 1 year ago
Thanks! Yes took that out. ASAP I understand that to be for the displays so they’re totally out now ( was getting a zero or two of them on player one for a while there) checked the fuse under the play field replaced it just in case
Coin up?
#4 1 year ago
Why replace fuses? Just check them with a multi meter if they are ok no need to replace.
What voltages are you getting on the test points on the SDB
#5 1 year ago
I don’t know how to test those. I have a dmm but which test points should I be testing ? It looks like there are a few on each board
#6 1 year ago
The SDB was just sent and it was all tested before which is what helped bring it to life (and replacing a 4A fuse). Just for reference
#7 1 year ago
Sounds like a connector issue. They are famous for causing these types of issues. I would check the upper connector on the right hand side of solenoid driver board.
#8 1 year ago
Set your DMM to lowest ohm range, typically 200ohms. Put one lead on one end of the fuse, one on the
Other. It doesn't matter which way. Meter should read 0 or a couple of tenths.
IMPORTANT!! Do this with the power off.
Better yet, take the fuse out of the holder.
#9 1 year ago
No testing the boards. Which test points do I use and what should the readings be?
#10 1 year ago
If you replaced the sdb board you should have re pinned all the connectors for it too.
#11 1 year ago
http://www.pinwiki.com/wiki/index.php?title=Bally/Stern
This has all the info you need on how to fix your game.
#12 1 year ago
Great info, thanks! I did find an 8AG 3/16 Fuse! That was like finding a needle in the hay stack (they're on line, but I wanted to find one today, so I can get back to trying to fix her)
Looking over the link, I am getting the immediate flash, then 6 flashes on the CPU LED. So I'm not getting that 7th flash. I'll get home later and start using the info in the link above to start trouble shooting.
#13 1 year ago
And no, I didn't re-pin any connections. There was no green slime and they all looked clean and good. Although one red one did slip out, but was pushed back in. Again it all worked for over an hour, or two. Then when I left for 1/2 hour to eat, then she wasn't responding.
So possibly these connections need worked over.
I'll keep everyone posted...thanks!
#14 1 year ago
had a similar problem with a supersonic , it turned out to be one of the program chips , i took it out cleaned it off and put it back in , problem solved , just be careful that you line up the tabs perfectly before you push it back in , they bend easy
#15 1 year ago
ahh, another good idea. I'm thinking the heat from the game did something...possibly to a connector, conductor, or even a chip like you're stating.
As a newbie - I'm taking this as one of the black small chips on the CPU/MPU board? For some reason I thought those were all soldered on, these just pull out and push back in?
#16 1 year ago
yes , just be careful you pull them off evenly . or you'll bend the prongs , they make a chip puller , or you can use a small thin screw driver and pry off alittle on each end till you can pull it off by hand , just also make sure you note which end the notch is at , so you put it back in the right way
#17 1 year ago
If you're not getting the seventh flash check TP3 on the MPU (lower left area). Should be about 22VDC.
#18 1 year ago
I’m getting 120v on TP3.
#19 1 year ago
Pulled chip at u10 and connector J4 per the reference docs above. (First chip so yes thought I was going to lose it getting that back on. Lol).
#20 1 year ago
Now down to just 2 flashes (after the initial flicker) and reading zero on TP3. Ugh. Think I’m going backwards ???
#21 1 year ago
Pulled chips at u8 and u9 (checking really to see if by pulling and re-setting I get contact).
Question - is the orientation of the chip an issue or can they go in either side up? (U9 didn’t have writing on it so I did install with the small dot on the bottom left as one of the others )
Verified no legs on the clips were bent over and all seem seated correctly
Relooked over fuses etc
But still now at 2 green flashes
#22 1 year ago
Ahh. Notch to the left. Then yes it’s in correctly. Whew!
#23 1 year ago
This might help narrow down the new flashing issue:
Flicker: MPU reset good, program booted.
1st Flash: ROM Checksums OK
2nd Flash: U7 6810 ram OK
3rd Flash: U8 5101 ram OK (U8 & U13 on mpu-200)
4th Flash: U10 PIA OK (see details for caveats)
5th Flash: U11 PIA OK (see details for caveats)
6th Flash: U12 555 Display interrupt timer OK
7th Flash: Zero crossing interrupt detector OK (solenoid voltage present)
http://pinwiki.com/wiki/index.php?title=Bally/Stern#Bally_.2F_Stern_MPU_Board_LED_Flash_Sequence
#24 1 year ago
Personally I wouldn't be pulling chips unless you know where the problem is. No third flash indicates bad U8 (5101)
Don't know how you could get 120V on T3?
#25 1 year ago
Think I’ve done something wrong in pulling these chips? To go from 6 down to 2 now? Or is this narrowing it down?
I’ve looked u8 & u9 over several times as I had one pin to curl when it wasn’t set properly. So now worried I’ve messed something up worse than when I started. But they look ok now. Ugh
Happy new year!
#26 1 year ago
Hell at this point reseat all the connectors on the rectifier board. J1 J2 and J3
But when you have all the connectors unplugged clean the pins the best you can with an eraser. You may need to reflow some solder on that board.
This thing was fine, you left it on a while now its acting up. Probably heat moving things around cracking old solder.
#27 1 year ago
Can you post a photo showing the area around U8?
#28 1 year ago
Yes and I made an error for :
Tp1 : 5.2
Tp2: 13.3
To3: 21.7
#29 1 year ago
Pull out the U8 and be sure none of the legs have bent under the chip. Then look closely into the chip socket. Make sure the contacts are clean and not damaged.
Your test points look OK. I think you made a typo - TP1 should be TP5?
#30 1 year ago
Let’s see if we can get the MPU to boot before doing anything else. The MPU only needs the power connector so remove all connectors from the MPU board except for J4. Power up the machine and watch the LED on the MPU board closely. Refer to post #23 by mrm_4 detailing what the flashes mean. The first flicker is very quick and faint and can be missed. This first flicker is not counted as a flash.
When you see a flash that means the test passed.
Count the flashes and report back. If the same as before, only 2, then there is a problem with U8, cmos ram.
Check voltages on the MPU board as follows:
Set your dm to dc volts and connect thEblack ground lead to TP4
Red meter lead to TP5, should be close to +5 vdc
Red meter lead to TP2, should be close to +12 vdc
Red meter lead to TP3, should be close to +19 vdc but will bounce around since this is unregulated voltage. This voltage comes through a resistor from pin 15 of J4 which should be +43 vdc. This is only neede to get the final 7th flash.
#31 1 year ago
Tp1 & 5 I’m getting same reading. Tp4 I’m getting 40. Pulled and cleaned u8 chip.
#32 1 year ago
Same Pulled all connections except j4. Still flicker and 2 flashes
#33 1 year ago
And sorry. I was putting my black lead on a ground. Let me check now
#34 1 year ago
5.1, 13.08, 21.8. Looks better thanks.
#35 1 year ago
Do they sell individual chips or chip sets? Change one means change all?
And can leaving it on, after not working for years I’d say , burn these up ?
#36 1 year ago
So the voltage to the board looks good. So likely U8 is bad. You checked the pins and none are bent so that is good. With U8 back in check the voltage on pin 22 of U8, should be +5 vdc.
#37 1 year ago
Just need to replace individual chips as they are found bad. If the 5101 is bad I can send you one, I have a number of good ones from installing NVRAM on boards.
The board booted past the 2nd flash before you started reseating chips, correct? The U8 is cmos and can be damaged by static although I have not seen this myself but I am also very careful handling chips. Also, chips have to be oriented correctly, if you put it in wrong after reseating it would have be damaged.
#38 1 year ago
I’m getting 4.6-5.2
#39 1 year ago
Yes. It was going to 6 flashes before I started reseating chips. Lol
#40 1 year ago
So next step, short of getting out the logic probe or oscilloscope, would be to replace U8.
Lack of 7th flash in your original problem is classic lack of 43 volts which typically is caused by a fuse blowing caused by selenoid problems.
If you want me to mail you a couple of 5101s PM me you address.
#41 1 year ago
Thanks That’s where it originally started when I brought her home. There was a 4A fuse blown on the rectifier board. Thinking it was this again I’ve replaced all fuses through out (before the chip issues today)
#42 1 year ago
F4 is for the 43 volts. My schematic shows that to be 5 amp fuse.
#43 1 year ago
I have and “MDL 5A”. Is the MDL correct? I see AGC. AGX. My main thought was matching the Amperage?
#44 1 year ago
Sorry. Siri. I have a MDL 5A fuse in there. But I’ve seen other fuses with the other accronyms
#45 1 year ago
https://itstillworks.com/difference-between-mdl-agc-fuses-7337905.html
MDL is slow blow. Aha. Should I find an AGC fast type? Looks like I’ve done that a few times
#46 1 year ago
Any progress?
#47 1 year ago
Should be receiving the chips today, will plug them in as soon as they hit the door step. Hoping this is all the issues, we'll see.
I've said it before, from the lady I've bought this from (and her late husband) to the pinsider sending her the replacement SD board, to the other pinsider sending me these chips - this is a game of love. One that I'm not flipping, one that will stay in my so called collection. Loved the look of it, and playing it!
Amazing peeps here on Pinside! (and now that I'm looking at my PM's, I was supposed to send a man some photos of my shuffle bowler...so I have not paid it forward...ugh, my bad!)
I'll keep this post updated, as it's also been a labor of love!
#48 1 year ago
Wow! What an update here- spent the day with “The Wiz”! Now I know why they call him that! Just an amazing day of learning - so much on these SS machines. Can’t say enough for all the help from everyone here - thank you !
In a nut shell some chips were bad a lot of connections both on the boards and the pin connections. Etc. this thing needed a lot of TLC!
If I could post a video , the first game was played by my youngest granddaughter and she scored big time and got the match to work !
Mata Hari is back in action!
#49 1 year ago
Great news, glad its back to life!
Displays
PinballSolutions.eu
$ 49.99
PinballElectronics.com
$ 19.99
Third Coast Pinball
$ 149.00
