Got a Mata Hari off eBay the end of last year in pretty decent shape in spite of some mice calling it home at some time in the past. Turned every piece of paper in pin to confetti but I have not seen any chewed wires at all. Rebuilt the flippers and was playing ball. Replaced all playfield bulbs with LED's and aside from a little flickering all was good. Earlier this month it stopped booting up and pulling out the molex connectors and re-seating got it back working, for a while so I ordered rebuild kits for all of them. Rebuilt the connectors on the rectifier board (which is a nice shiny replacement board from Gulf Pinball that came in the it) solenoid and light boards (forgot about the MPU connectors when I ordered but they are on the way now) Also installed new Alltek solenoid and light boards (she already had a Alltek MPU board) Fired her up and she came to life, back box clank and chime intro, press start button and get the chimes but "ball into play" solenoid, doesn't fire. Checked all fuse for continuity including one under playfield (that holder had some signs of age so I replaced it as well) Self-test most lights are on just not some on the lower field. No stuck switches and only solenoids 2-6 fire (back box and 4 chimes)
I see the lights for each solenoid test blink for each one on the Alltek board, does that indicate the board is trying to fire them and the issue is on the playfield?
What do I check next?
Bill
