I can get pictures of anything, or you can see any one of my game room videos. 3400 takes ALL of them. Package deals available. See the links for videos
(gorgar)
(most of them)
(most updated video)
Pinbot- 800 with extra pf
The playfield was poorly touched up, it has one switch error, and has a problem with the p2 display. I have an extra play field that I wont have the time to swap, being a college student. The extra pf is a solid 8 our of 10, but fully mylared.
Cyclone-800
The playfield is about a 7 out of 10. It needs to be shopped, and one ramp needs to be repaired. I will get detailed pictures, but they are very repairable. It is playable as it sits. the bottom row of the display does not work. The feris wheel works. It is fully mylared, including the haunted house drop target, meaning the target does not work. (Lazy operator)
Jokerz- 900
It was just shopped, sometimes it has a segemnt issue, sometimes it does not. Probably just a cracked or cold solder joint. I have not looked into it. It is in decent shape. It has some minor wear.
Gorgar-800
It has a sound issue. There is no speach. It has a reconditioned driver board in it, and it works well. player 2 and player 4 are missing the hundreds digit. The playfield is a 7 out of 10. The back glass is a 6 out of 10.
Space Invaders (Pinball Machine)- 900
Plays well, no problems, just some pf wear around the multiplier lights.
If you pay full price Ill throw in a SI deluxe cabinet for free. It is in ok shape, but has no boards or wiring harness. Everything else is there. 50 doloars if you just want the cab without the pinball machine.
