New! Dark mode!
(Topic ID: 142858)
Mary Shelley's Frankenstein
By Logos
  • 9 posts
  • 7 Pinsiders participating
  • Latest reply 4 years ago by robertg130
#1 4 years ago
Hi,
I have Sega Mary Shelley's Frankenstein pinball.
Dot matrix display stopped working where to start?
#2 4 years ago
Reset the connections to the dmd. Sometimes wiggling the connections while machines on will lead you to guilty connector.
#3 4 years ago
I'll try, but it happened all of a sudden, I smelled burnt.
How do I check the voltage?
Some one can a upload image with an explanation?
#4 4 years ago
There is a different cable available that was a fix for DMD problems. I would start with that. Mine came from Marco. It is a simple install, and might solve your problem. It even comes with the original install instructions from Sega. Even if you fix the problem with resetting the connectors, you should get this replacement cable (unless your machine already has it).
#6 4 years ago
Smelling something burnt is never a good thing. .. pretty sure on franky there is a 5 volt and a 12 volt. I don't have the manual in front of me.
#7 4 years ago
Unique coin door.
#8 4 years ago
check the plugs. there is a service bulletin about using a better 5 volt connection. You can find the cable at pinballlife.com If you dont have a digital multi meter (DMM) i would suggest finding some videos on youtube about checking DC and AC voltage.
#9 4 years ago
There is a bulletin for resolder pins and change conector
$ 209.99
Professor Pinball
$ 28.00
4,200
Metal-Mods
$ 21.00
2,850 (OBO)
Euless, TX
PinSound
Gweem's Mods
€ 339.00
Displays
GermanGamingSupplies.com
Great American Pinball
TheDudeMods
€ 60.00
Buthamburg
$ 9,999.99
Little Shop Of Games
