I'm having an issue with Mars God of War where it won't reset the drop target bank located in the middle of the playfield. The upper right one works fine.
When I do the solenoid test it does not fire. Actually nothing fires for solenoid 5 or 8 so i figure it's one of those. The other may be the knocker as I don't hear that firing either.
I don't have the manual so not sure which transistor drives that solenoid. I checked the driver board and replaced one mps045 and one of the 2n3055 that were bad. Unfortunately that didn't solve the problem.
The solenoid works if I manually fire it and resets the bank.
Also on my switch test it is telling me switch 54 is open. Anyone know what that switch is?
If someone has the manual and can clue me in on the above, I'd be most thankful.
