I selected item condition as "used but very good" or something to that extent. When the ad posted, it says the condition is HUO.
I do not see a place to specify the game's condition, and it won't let me post my ad without it. Using Firefox.
I used the "Sell this game" link from my collection to create the ad.
Still a bug. I've reported it twice via email, no response. Just wanted to follow up here.
Can't edit a PARTS FOR SALE post, as it has a game condition field but the dropdown is not populated. So you can't save.
I was able to somehow work around the bug using Internet Explorer (gack) to post the ad (which would not allow me to post pictures), then I was able to edit it in Firefox. After doing that, the condition dropdown also showed up fine for the subsequent ad I made in Firefox.
I'll try Firefox. The dropdown doesn't populate in Chrome for sure.
Hopefully this will get fixed soon!
I was able to work around the EDIT bug by changing the "item condition" <select> dropdown. For the parts forum, it has the "disabled" attribute set to "disabled". But the form validator requires a value. Using the developers tools, I removed the disabled attribute and was able to select a value and submit my update.
I have the problem where I placed the ad, including condition from the drop down.
Now I want to edit the ad, I make the necessary changes, submit, and an error message tells me I must select the condition from the dropdown box. I go to select the condition and it won't let me expand the condition drop down box. So it won't let me save the edit.
This means I can't edit an ad!
Safari and Chrome.
Quoted from CoreyStup:I was able to work around the EDIT bug by changing the "item condition" <select> dropdown. For the parts forum, it has the "disabled" attribute set to "disabled". But the form validator requires a value. Using the developers tools, I removed the disabled attribute and was able to select a value and submit my update.
Yep, that's basically the same thing I have to do.
Sorry for the slow reply! A big update is coming which, among other things, will finally fix this annoying bug. Stay tuned!
Quoted from robin:Sorry for the slow reply! A big update is coming which, among other things, will finally fix this annoying bug. Stay tuned!
Im still having the same issues after the update...I go to edit my ad's text, It brings up the edit screen, and the drop box for condition is reset to blank Then I go to commit and it gives me an error that I need to select condition. But it won't let me select the drop down for condition!
Quoted from cooked71:Im still having the same issues after the update...I go to edit my ad's text, It brings up the edit screen, and the drop box for condition is reset to blank Then I go to commit and it gives me an error that I need to select condition. But it won't let me select the drop down for condition!
That's strange, the condition problems should have been solved. Which ad is it? We will have a look at it tomorrow (CET).
Quoted from Martijn:That's strange, the condition problems should have been solved. Which ad is it? We will have a look at it tomorrow (CET).
https://pinside.com/pinball/market/ad/26728
Have tried it on Chrome, Safari (IOS and MacOS)
We found the bug and have fixed it on our development system. We'll push the update later today, so within a few hours you should be able to set the condition.
Quoted from Martijn:We found the bug and have fixed it on our development system. We'll push the update later today, so within a few hours you should be able to set the condition.
Works now....thanks.
This page was printed from https://pinside.com/pinball/forum/topic/marketplace-item-condition-bug and we tried optimising it for printing. Some page elements may have been deliberately hidden.
