(Topic ID: 312323)
Mandalorian sarlacc pit wireform attempt.
By Loganpinball
1 year ago
#1 1 year ago
First thanks to pinsider Mudflaps for putting out this idea and if I end up making these as a mod he is getting a kit for free for the idea.
I am making a scoop and wireform kit for Led Zeppelin pros currently and Mudflap asked if I considered doing the same for the Mandalorian pro. I looked at the manual and both the pro and premiums use the same opto switch for that horshoe or scoop. I will verify this when I get home. Pictures are from the Zeppelin scoop I am doing right now.
I am looking to see if there is enough interest in such a mod. It will be the scoop and additional 2 wireforms. One from the scoop and one to the right flipper. There will be two options if I make these. If you have my previous rails you only need the 2 new ones and the scoop. If you still have plastic ramps you will need 3 ramps and a scoop.
Video is just me holding a wireform to test the scoop.
If your interested please let me know. If I get 10 people I will absolutely make them.
13C18374-5E78-4895-8318-65F66E6159C4 (resized).jpeg13C18374-5E78-4895-8318-65F66E6159C4 (resized).jpeg55461640-4752-423B-8A44-98B5716F65E2 (resized).jpeg55461640-4752-423B-8A44-98B5716F65E2 (resized).jpeg
#2 1 year ago
Quoted from Loganpinball:
First thanks to pinsider Mudflap for putting out this idea and if I end up making these as a mod he is getting a kit for free for the idea.
I’m in, and I’m absolutely paying for it. Hopefully your time and effort with LZ will translate to Mando.
#3 1 year ago
Quoted from Mudflaps:
Count me in as well for mando, if it pans out. I've had a set of your rails on my machine from your first batch and they truly are a game changer. Great work, keep up the innovations and keep us posted.
#4 1 year ago
Any video yet of Mando; might be interested? Thanks...
#5 1 year ago
Id be interested in the Mando Pro kit
#6 1 year ago
Definitely interested in a Mando version!
#7 1 year ago
Interested.
I'm curious if there will be any code issues for shots that require the u-turn vs. the scoop.
#8 1 year ago
Great, thanks for the replies. I will make a set soon and post as it goes. I can use the scoop I made for Zeppelin, I did not want to sink time into a Mando version unless there was enough interest. The stainless plate will determine the costs on scoop. I will get on it once I get Zeppelin done.
#9 1 year ago
Quoted from medeski7:
Interested.
I have to see what switch triggers the horse shoe exit shot. My guess in #59?
Pro does not have switch #55 which is the scoop shot on premium.
I have to see what switch is the exit one and then see if we can move it to the scoop or wireform I am adding. Code wise should not make a difference as long as its only one switch for horse shoe exit. I will try and see when I get home. Thanks as I just assumed it was just a switch move.
2BDFC851-B395-47A0-B871-56EE539DC7E9 (resized).png2BDFC851-B395-47A0-B871-56EE539DC7E9 (resized).pngA5BC3822-6FBE-49C9-93A1-8DC417CB71F8 (resized).pngA5BC3822-6FBE-49C9-93A1-8DC417CB71F8 (resized).png
#10 1 year ago
Switch #58 according to your schematic. The u-turn has one switch, and moving it left should be very straightforward.
There are also options to use an opto, or a different switch altogether. This may require some mild soldering, but nothing terrible.
#11 1 year ago
Yes, I'm interested! Existing wireform customer from the 1st batch
#12 1 year ago
I’m in!
#13 1 year ago
I assume the Mando one would be down all the time, so maybe including a way to block the exit would be a good idea. Sometimes right orbit shots bounce in and you wouldnt want the ball to get stuck there.
This is very cool though, if I ever get a Zeppelin I'd definitely add this. In fact, this mod kind of makes me want to pick up a Zeppelin more.
#14 1 year ago
You the man!!! Can't wait to see how the build turns out.
#15 1 year ago
Quoted from shaub:
I am cutting stainless steel plate and making it a blocking wall. It will have a mount that goes into the switch hole and gets secured under the playfield. I see it in my head. I wont get to the Mando until the weekend. I am really looking forward to making this mod.
And I never gave Zeppelin pro a chance. I kept hearing Buffalo pinball podcast host saying how much he liked it. I played it at automated services on Monday and hes right. It really looks empty, but wow its just fun with great shots. If only they did ball lock in the Zeppelin. Amazing game by Steve.
#16 1 year ago
If this is anything like your wireforms for
Mando pro then I’m in. Your work is fantastic!
#17 1 year ago
That's a great idea. I don't own a Mandalorian but Im borrowing one from a friend, I'll definitely be telling him about this mod.
#18 1 year ago
I'm interested, I bought wire forms a while back.
#19 1 year ago
Quoted from alleycat-pinball:
If you have my rails already I will offer to modify your current rail to work with the additional mod. All you would need to do is mail me the left return rail I will modify it with new welded pieces needed to work with new mod for $20 and send it back to you with the new kit. It will cut $80 off the the total cost of mod.
I just need to verify that I can configure the new scoop rail to the existing left rail first.
#20 1 year ago
I would do that in a heartbeat.
Still have the box you sent the rails in.
Count me in.
#21 1 year ago
I have the OEM Stern metal ramps on my Pro. The u-turn ramp has a flat point intended to connect to the horseshoe rail.
Are you going to try and use that connection point with your new rail?
A8E07A87-B77D-4D7D-B73A-D6D9C60D5161 (resized).jpegA8E07A87-B77D-4D7D-B73A-D6D9C60D5161 (resized).jpeg
#22 1 year ago
This helps. A lot of us already have your rails installed. I imagine whatever change is made to the left rail would make it so we could use the rails with or without the horseshoe if we wanted?
#23 1 year ago
And it starts tonight.. it really helps when I want the mod for myself.
I am going to try making it adaptable to my previous set first. Hoping it works!
294FF1E2-B2CA-43AC-AFBD-708E5AF73614 (resized).jpeg294FF1E2-B2CA-43AC-AFBD-708E5AF73614 (resized).jpegC5BE61E6-36BF-4D59-A99D-FF820D807CF2 (resized).jpegC5BE61E6-36BF-4D59-A99D-FF820D807CF2 (resized).jpeg
#24 1 year ago
Split time between mando and zeppelin. I have to figure out a non hideous way to have the switch moved to scoop:rail? I stopped and went to zeppelin to ponder... late night but made good progress.
Scoop is mounted with two screws and it replaces the metal blocker. I welded a tab on scoop to replace that blocker.
211C95C2-241C-4817-A689-98D188428AF8 (resized).jpeg211C95C2-241C-4817-A689-98D188428AF8 (resized).jpeg80D6B9A7-4A02-423C-898A-2974A1405C57 (resized).jpeg80D6B9A7-4A02-423C-898A-2974A1405C57 (resized).jpeg
002E0F8C-FF44-407E-8D6B-CA9ABD6FEB2D (resized).jpeg002E0F8C-FF44-407E-8D6B-CA9ABD6FEB2D (resized).jpeg
#25 1 year ago
Question for everyone interested.
I am still working through mod. I did notice one issue with this. The premiums and le have selectable gate on this assembly. I think I know why. Any shot not strong enough, or a random shot towards scoop that is under powered will just roll back towards flippers after falling down scoop. Those same shots would roll around the curve easily. Is this a mod killer?? Please chime in.
#26 1 year ago
I don’t think this would kill the mod, but it’s likely assumed risk that the shot is not 100% identical to the LE.
I’d recommend a quick video with what the scoop can and can’t do. Let the buyer decide.
#27 1 year ago
Interested, will have to see how it turns out.
This is similar to the difference between pro and premium AIQ with the captain marvel ramp. Heck, if you can put that ramp into here instead if the scoop, that’ll work too.
#28 1 year ago
I finally figured out a solution for ramps that solves my issues on all of my projects including Tron!
Instead of a transition ramp I have wireform lift ball. Its perfect. Taking a break, but heres the basic one in progress. Very happy.
29F466A9-9F3D-4C31-A54F-EBCF0D996747 (resized).jpeg29F466A9-9F3D-4C31-A54F-EBCF0D996747 (resized).jpegC0D83840-76BE-4050-883E-FDA59D8B74B5 (resized).jpegC0D83840-76BE-4050-883E-FDA59D8B74B5 (resized).jpegC8E08C0A-5E65-4588-8C2A-5967760D327B (resized).jpegC8E08C0A-5E65-4588-8C2A-5967760D327B (resized).jpeg
#29 1 year ago
Instead of a transition ramp I have wireform lift ball. Its perfect. Taking a break, but heres the basic one in progress. Very happy.[quoted image][quoted image][quoted image]
Looks great! How does this connect to the right wireform?
#30 1 year ago
I'm curious so this shot will bypass horseshoe shot? I'm interested awesome work.
#31 1 year ago
I really like the look of that wireform. Almost looks like a hand reaching out of playfield.
#32 1 year ago
Quoted from acedanger:
Changes shot to scoop switch over u turn exit.
Quoted from JonCBrand:
I am working on adding Mythosaur skull on top and part of the wireform. (The hand looking area).
29D75DA9-945A-4AD7-A72A-5BE2E75AD6FC (resized).jpeg29D75DA9-945A-4AD7-A72A-5BE2E75AD6FC (resized).jpeg3D5524FB-FFCD-4C5A-A508-7D755A048CFA (resized).jpeg3D5524FB-FFCD-4C5A-A508-7D755A048CFA (resized).jpeg4ACF6222-3530-46D5-B8A3-0F445BE181F6 (resized).jpeg4ACF6222-3530-46D5-B8A3-0F445BE181F6 (resized).jpeg4BA473B6-2E0F-4DC9-912F-0D4580D57ECD (resized).jpeg4BA473B6-2E0F-4DC9-912F-0D4580D57ECD (resized).jpeg
87EF1BBC-DEDE-4432-ABD5-CA8C963ACDCE (resized).jpeg87EF1BBC-DEDE-4432-ABD5-CA8C963ACDCE (resized).jpeg
#33 1 year ago
Might be too much. Wont know until its sanded and polished. I think I need to 3d skull. Stopping for today, I need to add guides at lower part to finish. The ramp works...
I will make another one with no add ons. I just wanted to try the skull. There will be a simplified version very basic.
63343A55-EC6E-4FCF-B719-EB0E46665C0B (resized).jpeg63343A55-EC6E-4FCF-B719-EB0E46665C0B (resized).jpeg682C73D0-1B7B-48E6-ADFF-C72B14BB8C44 (resized).jpeg682C73D0-1B7B-48E6-ADFF-C72B14BB8C44 (resized).jpeg8310C9AB-1A1D-4CF6-A37A-DD9C74DA2311 (resized).jpeg8310C9AB-1A1D-4CF6-A37A-DD9C74DA2311 (resized).jpeg
6 months later
#34 7 months ago
I am not able to make 180 degree looping ramps to my standards. I am at a point where I am bored with Mando and I have creative issues in my head. As a result I am going to remove the turn around ramp assembly and convert it into a 2 ramp shot fed into wireforms. I will also drop the main right ramp down into new wireforms. I have artistic demensia and this is next. Taped out basic idea of travel see picture. As designed there will be no wireforms running across.
A0CF0941-038A-4E77-BF4F-2650942924D1 (resized).jpegA0CF0941-038A-4E77-BF4F-2650942924D1 (resized).jpeg
#35 7 months ago
Looks like an ambitious project, looking forward to seeing how this progresses.
#36 7 months ago
Yeah that would be cool. The improvement though by removing the plastics and putting in your wireforms was huge.
#37 7 months ago
Quoted from Groo:
Its a game that should not have plastic ramps going across the playfield, mine or Sterns. I am just bored of the game as all I have done is playtested wireforms on it for a year now. If I can make something unique for myself I will keep it. If I don’t I will sell or trade it. All I have ever done is playtest and fit test wireforms almost 400 times. (2 per set) and it has killed my interest in the game as a result. Its a beautifull game and one of the better star wars machines. Just stripped it down.. lets see what
134FBAF6-9CAF-4789-8164-3589511EA69A (resized).jpeg134FBAF6-9CAF-4789-8164-3589511EA69A (resized).jpeg8D32E53E-FE68-4DC1-A47C-A1226D036EB2 (resized).jpeg8D32E53E-FE68-4DC1-A47C-A1226D036EB2 (resized).jpeg9666F052-1B44-4942-8886-0B467CFCC43E (resized).jpeg9666F052-1B44-4942-8886-0B467CFCC43E (resized).jpeg
#38 7 months ago
Going to try and make a sarlacc pit wireform transfer in the rear corner. I want to have the two other new ramp shots incorporated as well. I see it in my head and theres alot of room to attempt it.
055CBDBB-F5AC-44F4-96FD-76E957F71FC2 (resized).jpeg055CBDBB-F5AC-44F4-96FD-76E957F71FC2 (resized).jpeg79FC6D10-3811-4ED9-9918-288655787E08 (resized).jpeg79FC6D10-3811-4ED9-9918-288655787E08 (resized).jpegF43A6F41-6547-40AD-92D1-4EC92FF5FA25 (resized).jpegF43A6F41-6547-40AD-92D1-4EC92FF5FA25 (resized).jpeg
#39 7 months ago
Wow stellar work looking forward to seeing how this all turns out !
#40 7 months ago
Quoted from Cire113:
Thanks. Roughing it out now. The new insert ramp on the right side shoots upwards back on to the spiral wireform. I am working on a one way blocker that will stop the ball 3/4 of the way up and drop it to the new leftside wireform return. A weak shot would go up spiral and then fall to right return.. on paper and in my head it works. We will see.
AE48E007-1C29-4438-BA8E-B761E83FAAA4 (resized).jpegAE48E007-1C29-4438-BA8E-B761E83FAAA4 (resized).jpegBDB9F5A8-8530-4B63-B00D-EBC62E211FA1 (resized).jpegBDB9F5A8-8530-4B63-B00D-EBC62E211FA1 (resized).jpeg
D3BB537E-D496-4C77-AE66-EA5855126C37 (resized).jpegD3BB537E-D496-4C77-AE66-EA5855126C37 (resized).jpeg98E3ACC1-0A54-4E2B-8EC1-48E46EB5A8AC (resized).jpeg98E3ACC1-0A54-4E2B-8EC1-48E46EB5A8AC (resized).jpeg9A586FC8-0AC3-41B2-81ED-7E2076472093 (resized).jpeg9A586FC8-0AC3-41B2-81ED-7E2076472093 (resized).jpeg
$ 649.95
Pin Stadium Pinball Mods
Led
Toys/Add-ons
$ 45.00
arcade-cabinets.com
Armor and blades
Lighting - Backbox
Myth Pinball Parts Shop
Backbox
Precision Pinball prod.
Flipper parts
$ 89.99
Maine Home Recreation
Decals
6,500
Elk Grove, CA
€ 70.00
Pino Pinball Mods Shop
Toys/Add-ons
Various Other Swag
JK Pinball
Various other swag
€ 48.00
Toys/Add-ons
arcade-cabinets.com
Armor and blades
$ 22.95
Protection
$ 65.00
Diddy's Pinball Mods
Toys/Add-ons
$ 110.00
Toys/Add-ons
6,999
Milford, CT
$ 129.99
Shooter rods
80 (Firm)
Woonsocket, RI
$ 420.00
PinWoofer
Sound/Speakers
JK Pinball
Toys/Add-ons
Trade
Machine - For Trade
Brookings, OR
Pinhead mods
Protection
$ 299.95
Led
$ 19.95
Playfield - Plastics
Plastics
$ 130.00
Pin Monk
Flipper parts
Gweem's Mods
Sound/Speakers
$ 8,500.00
The Pinball Place
$ 1,999.00
Toppers
$ 19.95
Pin Monk
Other
Space Coast Pinball
Sound/Speakers
WilliPinball Mods
Toys/Add-ons
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/mandalorian-pro-premium-wireform-kit-interest-list and we tried optimising it for printing. Some page elements may have been deliberately hidden.
