if you have the broken ramp, use bondo or some sort of putty to make a "positive" mold from it, then you need a vacuum box, a shop vac for suction and some sheets of plastic specifically made for vacuum moulding (like PETG, etc)
You heat the plastic sheet in your oven until it reaches a certain temp and starts to dip, you pull it out and place it on the vacuum box over the positive mould, turn on the shop vac which sucks it over the mould. wait for it cure/dry.. pop it out. cut away the excess plastic, drill mounting holes, etc etc.
http://www.instructables.com/id/Make-a-good,-cheap,-upgradeable-sheet-plastic-vacu/
it is by no means easy, but if you need a ramp and have no other option (and have some time to dink around with this) it could be interesting.
