How do you make plunger springs stronger/weaker?
Can I modify what I have or do I need to buy a few and test?
How do I know the strength of what I have so that I know what to get (stronger or weaker)?
is it a manual or electric (automatic) one? Marco carries different tension springs to swap in. I did that with waterworld. Came with a very strong one and had to drop to a medium-high one.
It's a manual plunger.
But how do I know what to buy? Just buy a few and hope one is weaker than what I have?
There are two different strengths that I know of. The stronger springs I've seen are red, and if you are purchasing one they usually say "For games that need stronger springs such as blah blah".
Oh, ok. I have a Pinbot. The spring I currently have can make the ball hit the glass when it goes up the Vortex ramp. My ramp has the common broke off top tip (probably because of strong springs!) that prevents that from happening.
I now wonder if the weaker would be too weak to send the ball up the Vortex...
What about shortening the spring? Would that help?
I see from your collection that you have a Firepower. I'd pop the E clip off of that and swap the spring over to your Pinbot and see how it works. You could shorten your existing spring if that doesn't work.
Quoted from Marcuni:It's a manual plunger.
THey cost like 98 cents a piece, I bought each one. But after that I would only buy the medium-hard, hard and super hard. Got mine from Marco, but I bet PBL and PBR have them among others.
They have
soft, soft-medium, medium, medium-hard, hard, really hard
Different color springs are different wire diameters.
The smaller the wire diameter, the weaker the spring.
I would measure them with a pair of calipers - the paint on the springs often wears and flakes off, and it's a guessing game as to what is installed if you don't measure them.
Want it stronger? Go with a larger diameter wire. Weaker? Go the other way.
Pinbot, from the factory, used 10-148-3, blue.
10-148 spring-shooter black .031
10-148-1 spring-shooter silver .035
10-148-2 spring-shooter red .042
10-148-3 spring-shooter blue .038
10-148-4 spring-shooter green .033
10-148-6 spring-shooter brown .026
10-148-7 spring-shooter white .028
i just recieved my order from pinball life today. i ordered 2 new plunger springs. some rubbers,leds and new balls for my pinbot. i will post this weekend when i get time to install the new spring.
i just finished putting a new plunger spring,outer barrel spring and shooter tip in my pinbot.
i ordered a standard one and a red one from pinball life.i used the red shooter spring as the spring that was in it was shot. the red spring is a little firm as if you pull it all the way back it rockets up to the top of the skill shot. i also put white led flashers in behind the visor and they look AWESOME! i highly recommend them.
This page was printed from https://pinside.com/pinball/forum/topic/making-plunger-springs-strongerweaker-questions and we tried optimising it for printing. Some page elements may have been deliberately hidden.
