Quoted from ImNotNorm:Just to confirm....because....I'm an idiot
1- install dmd in place
2 - run red and black wires from dmd into the Lower cabinet under the playfield
3 - solder together female connectors to the additonal 16 gage red and black wire. (To reach power source)
4 - solder together U connectors to the additional 16 gage red and black wire ( so it can be soldered to power source)
5 - connect females with dmd's corresponding black and red wire
6 - solder U connectors to power source (red) and to ground (black)
7 - solder outlet cable to power source
8- plug in and play
The only question(s) I have is....
Does this power source looks right? (PSF100-12 model)
And where do I solder the red wire (dmd power) and black (ground) into the power source? (V, V+ or the other one)
Thanks so much and hopefully I'm done pestering everyone after the installation
Hopefully these pictures are worth a thousand words.
Since the dmd already had male ends, in crimped female ends to my black and red wire extensions. I then crimped U connectors to the other ends and connected them as shown.
Hope this helps.
