Got my Gottlieb Magnotron in 1977. Moved across country a few times, set it up in the basement gameroom where it played for years. Haven't played it for years but when it last played the center lite (or it could have been all 3 bumpers dead I just don't remember) was dead as it kept blowing the fuse.
I moved it upstairs and figured I'd trouble shoot it but now, to my surprise, while everything lights...all action is dead. No flippers, no bumpers no score. I can turn it on, get games, start the games and you hear everything resetting, the little holes that kick the ball out will work, but bumpers don't pop nor any score or flippers...it is as if it tilted...which btw, will setoff the tilt light if the vertical tilt switch touches. The pendulum tilt switch is inop.
I poked around but do not see any thing obvious other than a loose green wire (obviously wrapped around something...a ground perhaps) and another green wire that has burned thru and sparks brightly if touched. (as depicted by the straws)
