Quoted from Roostking:
I am no electrical engineer by any stretch, but if the magnet was drawing more power than normal(IE no wobble on the ball) would maybe a transistor be out??
Possible. It could be shorted to ground through a number of sources. I'm not familiar with how often Stern boards have issues like this or how the circuits for the magnet(s) work exactly so to simplify it to 'Transistor' is a bit premature, but possibly valid.
There's a magnet control board under the PF as well that may or may not control how that magnet grabs and could also be suspect.
Since I am a noob, im going to replace the fuse and go from there, if it happens again, Ill contact stern, as I dont want to void my warranty by disconnecting stuff.
Thanks for your help!
In my opinion you are risking more by just plugging a fuse in and turning it on again. If you are worried at all, call Stern BEFORE doing that. Fuses are nice circuit protection, but they need overcurrent for a time duration, and they are not a guaranteed failsafe for damage.
Disconnecting the magnet is one plug under the PF if I'm not mistaken and it shouldn't void anything by plugging and unplugging it. People were having coffin magnets overheat bad awhile back and it's as simple as unplugging it from power. If you DON'T unplug it, putting a fuse in and having the problem repeat again puts the magnet at risk again.
Bottom line: I would call Stern before doing ANYTHING, or I would disconnect stuff and try troubleshooting (as I believe this is what Stern will get you to do anyway but may be better directed by them in your case).
