I have an X Files I am restoring which has Playfield wear by magnet. I am considering using Bondo to fill/repair. Any thoughts?
I was going to use Bondo Rotten wood prep 1st. This product stiffens loose wood to create a solid foundation for Bondo filler.
Should I remove more wood in repair area to make a deeper void? Or leave it as is and begin repair?
I plan on air brushing after repair, but need to learn how to air brush 1st. What primer should I use prior to air brushing and is there a primer that can go through the air brush to avoid brush strokes?
