Quoted from YeOldPinPlayer:Your video shows sw 41 working, but it also shows 42 Genie Target is made (below sw 41) and 31 Trough Eject are made. The rest of column 3 looks normal if you have the balls out.
First a question, then new information that has come to light: You mention 42 Genie is "made." What does that mean? Is that the way it should be? When the genie is forward, it is "made," and when I push it like it is being hit by a ball, it changes to a dot. But I figure that's how it should be, right? That's also the way the optos show up on the switch test.
NEW INFO:
When coin door is closed and genie is made (normal position? pulled forward and the metal base is not touching the receiving piece of metal at the back), Ramp Made Left and Slam Tilt activate together. Said another way, when coin door is closed and Genie is in normal position (forward) Ramp Made Left and Slam Tilt activate together. When either the coin door is open or the Genie is pushed back like it is being hit, Ramp Made Left and Slam Tilt act as they should. I feel like if I was more educated, this would be enough info for me to know how to fix it.
